Hello,
I have a chance to get a Intel® Core™ i7-975 Processor Extreme Edition (8M Cache, 3.33 GHz, 6.40 GT/s Intel® QPI) for $250... I have a Intel® Core™ i7-950 Processor (8M Cache, 3.06 GHz, 4.80 GT/s Intel® QPI) now.. I do alot of 3d modeling and Cad/Cam programming... I also game on it sometimes... Will I notice a difference if I get this processor? I have 12gbs of gaming ram and two SSD drives... I have a 1366 socket mother board so it will fit.... Or would I be better with more cores like a i7-970 six core processor..
i7-950 Specs
EssentialsStatus
LaunchedLaunch Date
Q2'09Processor Number
i7-950# of Cores
4# of Threads
8Clock Speed
3.06 GHzMax Turbo Frequency
3.33 GHzIntel® Smart Cache
8 MBBus/Core Ratio
23Intel® QPI Speed
4.8 GT/s# of QPI Links
1Instruction Set
64-bitInstruction Set Extensions
SSE4.2Embedded Options Available
NoLithography
45 nmMax TDP
130 WVID Voltage Range
0.800V-1.375VRecommended Customer Price
$294 - $305Memory SpecificationsMax Memory Size (dependent on memory type)
24 GBMemory Types
DDR3-800/1066# of Memory Channels
3Max Memory Bandwidth
25.6 GB/sPhysical Address Extensions
36-bitECC Memory Supported
No
Graphics SpecificationsIntegrated Graphics
No
Package SpecificationsMax CPU Configuration
1TCASE
67.9°CPackage Size
42.5mm x 45.0mmProcessing Die Size
263 mm2# of Processing Die Transistors
731 millionSockets Supported
FCLGA1366Low Halogen Options Available
Yes
Advanced TechnologiesIntel® Turbo Boost Technology
YesIntel® Hyper-Threading Technology
YesIntel® Virtualization Technology (VT-x)
YesIntel® Trusted Execution Technology
NoAES New Instructions
NoIntel® 64
YesIdle States
YesEnhanced Intel SpeedStep® Technology
i7-975 specs
EssentialsStatus
LaunchedLaunch Date
i7-975# of Cores
4# of Threads
8Clock Speed
3.33 GHzMax Turbo Frequency
3.6 GHzIntel® Smart Cache
8 MBBus/Core Ratio
25Intel® QPI Speed
6.4 GT/s# of QPI Links
1Instruction Set
NoLithography
45 nmMax TDP
$1059Memory SpecificationsMax Memory Size (dependent on memory type)
24 GBMemory Types
No
No
1TCASE
67.9°CPackage Size
Yes
NoIntel® 64
YesIdle States
YesIntel® Demand Based Switching
NoThermal Monitoring Technologies
NoExecute Disable Bit
Yes
Yes
Yes
	Might be a tiny bit more faster but not worth spending another $250.A i7-970 would be better. I think,therefore i am a hamster.
	overclock your cpu ( i7 can easily go to 4 ghz ) and spend your money on nvidia (cuda)based graphic card like gtx 570 or better( if you don't have already even so ) it will help massively on 3d render and gaming more than just cpu upgrade . If you ask me not worth it
  Intel Q6600 Kentsfield or Intel E8400 Wolfdale??? Help me decide which oneBy budz in forum ComputerReplies: 33Last Post: 12th Mar 2009, 01:19
  Daytek 950-S, the story so far....By oldfart13 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 4th Dec 2008, 15:55
  Daytek 950-S burner replacement requestBy oldfart13 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 22nd Jul 2008, 10:24
  What should I do w/ Video OpenDivX4 720x480 24.975 PAL/NTSC? fix or convertBy JoeBolden in forum Video ConversionReplies: 1Last Post: 15th Dec 2007, 23:12
  Happauge WinTV-HVR 950: Using other softwareBy Scooter_NJ in forum Capturing and VCRReplies: 2Last Post: 20th Sep 2007, 18:29
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
