Hi guys!
i want to encode an anime episode, the source is mkv, what you think is a best settings from the following:
settings 1:
program --level 4.1 --pass 2 --bitrate 1000 --stats ".stats" --deblock 1:1 --b-adapt 2 --no-weightb --ref 4 --qpmin 10 --qpmax 51 --vbv-bufsize 50000 --vbv-maxrate 50000 --aq-mode 0 --me umh --direct auto --subme 6 --psy-rd 0.6:0 --output "output" "input"
settings 2:
program --pass 2 --bitrate 1000 --stats ".stats" --deblock -2:-1 --bframes 16 --qpmin 10 --qpmax 51 --no-mbtree --aq-mode 2 --merange 12 --me umh --direct auto --subme 5 --output "output" "input"
settings 3:
program --pass 2 --bitrate 1000 --stats ".stats" --deblock 1:1 --bframes 16 --no-weightb --ref 8 --qpmin 10 --qpmax 51 --aq-mode 0 --me umh --direct auto --subme 6 --partitions all --trellis 2 --psy-rd 0.6:0 --output "output" "input"
More details are needed. What is the source (codec etc)? It is interlaced or progressive? Encode samples and see what looks best. Are you encoding using x264?
more details
the source
Format : Matroska
Format version : Version 2
File size : 762 MiB
Duration : 23mn 14s
Overall bit rate : 4 582 Kbps
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 23mn 14s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive -
Sorry I don't have any experience with x264. Why are you reencoding? Is it for a specific device? Otherwise I don't understand why you would bother?
Anime encoding help
By carasy in forum Video ConversionReplies: 3Last Post: 28th Nov 2010, 18:07 -
help encoding anime w/ handbreak
By Ronin Silfar in forum DVD RippingReplies: 22Last Post: 29th Jan 2010, 21:28 -
Encoding anime
By prnoct90 in forum Video ConversionReplies: 3Last Post: 25th Nov 2009, 05:38 -
Anime Encoding From DVDs to h264.
By kwanbis in forum Newbie / General discussionsReplies: 9Last Post: 11th Mar 2009, 19:31 -
Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?
By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 15:31
