Hello,
I have a question if it`s possible to set the command for FFMPEG for Windows like this:
take everything in .avi from folder A and to process it to folder B in mp4
Example of script I would like to do:
C:\video\virtualdub\vdub.exe /s c:\video\scripts\h264_mp3_2.vcf /b c:\video\IN c:\video\OUT /r
c:\test\ffmpeg\bin\ffmpeg.exe -i c:\video\out\Test-B.avi -vcodec copy -acodec libvo_aacenc -ab 256k c:\video\finis\test-B.mp4
Where I would like to substitute the specific input item Test-B.avi and output item Test-B.mp4 to variable, simply something like *.avi -> *.mp4.
I also need to be able to process more videos with one loading of bat file.
I hope it`s understandable, what I would need and hope somebody could help. Thank you very much in advance.
If I have done the script below correctly (which I probably haven't), every AVI found in
c:\video\out\ will be processed by ffmpeg and saved as MP4 to c:\video\finis
Code:c: chdir c:\video\out\ for %%i in (*.avi) do ( c:\test\ffmpeg\bin\ffmpeg.exe -i "%%i" -vcodec copy -acodec libvo_aacenc -ab 256k "c:\video\finis\%%~ni.mp4" ) pause
Just something I noticed: If you are telling Virtualdub to create a H.264/MP3 AVI file, you might be better off instead telling it to create a H.264/WAV (uncompressed audio) AVI file, since you will lose audio quality by using a lossy format (MP3) as an intermediary.
ffmpeg create Chapter
By lspy in forum Video Streaming DownloadingReplies: 2Last Post: 30th Sep 2011, 11:20 -
Multiple filter problem with ffmpeg - help please?
By Orinoco Womble in forum Video ConversionReplies: 6Last Post: 6th Sep 2011, 19:09 -
Encode with FFMPEG with multiple input files...
By RogerTango in forum Video ConversionReplies: 3Last Post: 20th Jun 2011, 02:12 -
Applying multiple filters at once with FFMPEG
By asterixvader in forum Video ConversionReplies: 3Last Post: 1st Jun 2011, 15:53 -
Adding multiple title tasks to a video
By nam207 in forum EditingReplies: 1Last Post: 22nd Nov 2007, 09:02
