Results 1 to 16 of 16
  1. I have an "empty" 16GB USB memory stick. (See screenshot). However there is 85.9MB on the memory stick. Windows is set to view all files including protected files, and Windows shows no files on the memory stick. I would like to see what are the 85.9MB files.
    Nov 2005
    u can try USB Show
    my guess is its the security software that came with the drive.
  3. Enable the display of hidden and system files in Explorer.
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    OK OK....you caught us. It's us.... "Big Brother". It's our spying software on that stick. Now you have ruined everything. We are going to turn ourselves into the police now. Goodbye.
  5. Could be the drive partition table, though that seems kinda big. I know the DoD forbids flash memory drives because they found drives with code "burned" in to the chips. Try reading it on a different OS like MAC or Linux.
  6. Originally Posted by jimdagys View Post
    You need also select to Show hidden files and folders in folder options
    Probably folders $RECYCLE.BIN and System Volume Information are the 85.9MB files
  7. I have already selected to show hidden files, as stated in my initial posting. See screenshot.
  8. Originally Posted by jimdagys View Post
    Did you see folder by name System Volume Information?
    that folder contain 85.9 mb
  9. Windows explorer shows no files or folders are on the memory stick. I'll try Linux and report back.
  10. Using puppy linux, I also don't see anything on the memory stick. I know this linux is showing hidden files, because I can see the usual hidden files on the c drive, like "recycler" and "system volume information".
    It seems that virus makers would have a bonanza on this- Files that can't be seen in either Windows or linux.
  11. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    As far as I'm aware, Puppy Linux defaults to not showing hidden files and folders, so if you haven't specifically enabled it... (Other Linux distros most likely default to not showing hidden files and folders, too.)
    Are you sure the drive isn't one of those with a 'special' partition with the manufacturer's security setup, etc., in it? Who manufactures the drive?
  12. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    On more than one occasion I've seen 16GB memory devices listed as 14.9GB of actual usable space.
  13. Originally Posted by Ai Haibara View Post
    But the dialog he pictured is showing the partition size, not the drive size.
    That's because Windows shows the size in GiB (1024*1024*1024). Drive manufacturers give the size in GB (1000*1000*1000). 14.9 * 1024 * 1024 * 1024 = 15,998,753,177.
  14. DECEASED
    Jun 2009
    Heaven
    Open a command prompt, and run "chkdsk d:"
    What does it say
  15. When I run "chkdsk d:
    a dos window pops up for a few seconds and then goes away. I took a quick screenshot before the window disappeared.The memory stick just is marked "Microcenter 16GB", nothing else. Microcenter sells these bulk, loose, not in a package. See attached picture.
  16. Open a command prompt, the type CHKDSK X: where X is the drive letter of the flash drive. D if the image in the first post is current.
