I downloaded the latest Ripbot264 this morning an installed it. When I open Ripbot it reports that Java is not installed even though it really is. I then downloaded the latest 64-bit JRE and installed that to the default directory, and still Ripbot says Java is not installed. Do I need to use the x86 version of JRE? Or do I need to install Java in a specific directory for Ripbot to see it? I am running Windows 7 64-bit.
32 bit programs run in a 32 bit space, 64 bit programs run in a 64 bit space. They are two separate systems under 64 bit Windows.
The same OS installed on two disks
By Jomapil in forum ComputerReplies: 29Last Post: 4th Jun 2009, 15:35 -
No Audio output installed
By ray316 in forum ComputerReplies: 1Last Post: 12th Mar 2009, 16:53 -
Installed software ,No Discs?
By visionman in forum ComputerReplies: 5Last Post: 14th Jan 2009, 16:43 -
Just installed and failed
By cantthinkofanickname in forum Newbie / General discussionsReplies: 12Last Post: 21st May 2008, 12:20 -
Why do programs need to be installed?
By Rudyard in forum ComputerReplies: 18Last Post: 18th Jun 2007, 09:00
