i have audio length 1:50:01 and video is 1:57:06 so how can i add this audio to video with exact video picture and make dual audio.
Please help . i am working this about 1 week. i tried mkvmerge but not get proper audio with video.
I am Waiting for you best answer.. If you have any link then you can send the link i will do according to steps of link.
Results 1 to 18 of 18
You can start by try "stretch" the audio with audacity, http://www.youtube.com/watch?v=zdwQ9ShmPrg and see how it syncs with the video. But it will probably also require some manual editing to get exact sync.
Or change the frame rate of the video at the container level. Multiply the frame rate by 1.0644.
But you'll often find there's more than just a different length. It's often different cuts of the movie. -
You can modify the frame rate to math the audio in Virtualdub. Select video/frame rate/ match to audio.
Set video to direct stream copy and save as a new AVI.
One problem is, although it may be fine to play it on the computer, external devices may not play it properly,
since the F/R is non-standard now. -
Start MMG. Add the video track. Add the audio track. Highlight the audio track. " Press the Format Specific Options" tab. In the "Delay (in ms)" field enter the delay you want, in milliseconds. For example if you need a 3 second delay enter 3000. If the audio needs to be advanced rather than delayed enter a negative number. Press the "Start Muxing" button. Done.
hi again friends,
I have video which is lower quality in hindi language and its 30 FPS, so i download HD quality movie in English language and its 23.976 FPS, so i extract hindi audio from mkvmerge , and after that i add hindi audio in HD quality movie through mkvmerge , but now problem is that hindi audio is not match, i also use delay (ms) but now problem is that audio going proper way at 4 min but when video reach at 15 min then hindi audio not match, so how can i convert 30 FPS audio to 23.976 audio ? is that possible ? because i think audio don't have FPS , so how can i do this job. ? please help friend... because now i am tired to searching those think...... please.......... -
It might be easier to change the frame rate of the video at the container level.
You can use an audio editor like Audacity to stretch or squish the audio length.
But releases in different countries often are different cuts of the movie. So simply adjusting the audio length or frame rate may work.Last edited by jagabo; 30th Dec 2011 at 09:37.
Hey friend, Now i sync hindi audio with exact length of 1:56:06. so when i muxing in mmg (mkvmerge) then video frame may not proper when it start, after 5 or 6 sec. video going proper way and proper audio. but when i fast forward in vlc (clt + right arrow) then again frame are like garbage , so how to solve this garbage video frame. ?
how to solve corel videostudio pro x4 unspecified error ? when i insert audio file , and wanted to show waves of audio, then it give me unspecified error and program close. How can i solve this issue ?
How to change date and time of MP4 (or any format) video file ? Any software's available for that ? if possible then how ?
Get Two AVI Video Framerate's to match
By Simmons in forum Video ConversionReplies: 4Last Post: 15th Aug 2011, 10:02 -
Audio does not match with the video
By c018279 in forum Blu-ray RippingReplies: 1Last Post: 31st Mar 2009, 05:10 -
Video and Audio does not match
By hzgg2 in forum Authoring (DVD)Replies: 1Last Post: 1st Aug 2008, 20:50 -
cant get audio to match video
By loa909 in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 07:35 -
Conversion of audio to match video
By deltaromeo in forum AudioReplies: 11Last Post: 29th Jan 2008, 13:01
