  1. Hi,
    Maybe some or you know or not, but there is a brand new kmplayer version out 3.1.0.0. With it comes kmp+ which are services being provided within kmplayer to extend from being a media player to much more. Here is a link to learn more about it.
    http://www.facebook.com/kmpmedia?sk=app_288557114521398
    Official download page or you can download from videohelp of course
    http://www.kmplayer.com/forums/showthread.php?t=22193
    Lots of great features are being planned in the feature for kmp+
    So, what do you all think of it, please reply thanks!
Name:	KMP+ main screen.png
Name:	KMP+ Visual EN.jpg
  2. Is it me, or is KMPlayer ALWAYS in beta?
  3. Yes, mostly but this a very different beta version.
  4. A patched version 3.1.0.0 R2 is out. Fixed is the mkv source filter.
  5. New 3d version with support for 3d videos!
    http://www.kmplayer.com/forums/showthread.php?t=24627
Name:	3d blurry.png
Name:	3.2 main1.png
    Mar 2011
    Nova Scotia, Canada
    You just fixed mkv support?
    You actually try to make the fact that you need crap 3rd party codecs/filters a virtue?
    Did you know that Microsoft tech support specifically states that on a Windows 7 system you should not use any 3rd party non Microsoft codecs or filters or splitters?
    Did you also know that they aren't necessary? Any good program can work with directshow/directx/.net framework with its own codecs. Anything else is hacker crap.
    I tried this program on my older computer once. It ain't going anywhere near my newer one.
  7. KMPlayer 3.2 changelog:
    Changelog:
    ** 3.2 UPDATE LIST **
    - Supports 3D Formats. (Side-By-Side, Top-and-Bottom) to (Anaglyph, Interlaced)
    - Supports 10-bit H.264. (Libcodec.dll)
    - Supports Intel Widi.
    - Added video codec "DV5P".
    - Add new function album art (Thumnail image extraction from FLAC file)
    - Thumbnail image display enhancement when playing audio files. (MP3, FLAC, WMA)
    - Fixed ColorSpace bug.
    - Fixed Intel Codec H.264.
    - Fixed Winamp plugin.
    - Error correction of images infected with malicious codes. (EIP register Corruption Vulnerability. Provided: KISA)
    - Fixed view as a desktop mode in Windows 7.
    - Fixed improper load of Album Art bug.
    - Correction of screen display error when using EVR(C/A) - if you skip from the WMV file.
    - Fixed KMP HTTP Reader.
    - AAC codec Parser error correction from MOV file.
    - MKV Skip Problum.
    Build 19:
    Updated(2012-03-27 12:20)
    Exe File Version : 3.2.0.19
    - Waiting indefinitely large TS file for error correction.
    - OGG file playback for error correction.
  8. KMPlayer 3.3 beta build 28 is out!
    http://www.kmplayer.com/forums/showthread.php?t=32923
    ** 3.3 UPDATE LIST **
    - Added Web Search Bar.
    - Supports Blu-Ray Play.
    - Supports DIVX(xsub) Subtitle(AVI files only).
    - Added video codec ProRes(APCH, APCN, APCS, ACPO, AP4H).
    - Added video codec(IV50, RV40).
    - Fixed AVI source filter(Supports playing damaged file).
    - Fixed MKV source filter(Improved performance).
    - Fixed RM, RMVB file seek error & Supports damaged file play.
    - Fixed ASF file error.
    - Fixed URL Play for AVI file.
    - Fixed display infomation for MP3 bitrate.
    - Fixed background resize error of SWF play.
    - Fixed overflow of memory error when external audio file is used.
    - Fixed access violation when updating.
    - Fixed file name display error while starting a playback.
