Hi all!
I am looking for a lossy 32 bpp codec which I can encode my video into.
I am currently aware of the following lossless codecs:
Apple -> None
Apple -> Animation
JPEG 2000
Fraps 1
My goal is to get a 30 seconds video with 32 bpp color depth to weigh well under 100mb. Wide compatibility like the MPEG codec family is always a plus.
Any help will be immensely appreciated!!
Results 1 to 10 of 10
You mean you need to keep the alpha channel? And you need to keep the video in RGB, not YUV 4:2:2 or 4:2:0?
I am not sure about the alpha channel question. It may be the alpha but it could also be because of the higher bpp?
As far as RGB. Yes I would like to start off retaining the RGB format. However so, I am open to a 32 bpp YUV if such a format supporting codec exists. -
32bpp means 32 bits per pixel (8 red, 8 blue, 8 green, 8 alpha)
"bpc" as a naming term is often used interchangably with "bpp" (bits per channel, or bits per pixel)
If you don't need alpha channel , then use 24bpp . Because alpha channel requires bandwidth (=larger filesizes), even if it's a "dummy" channel with no data -
Checking the video properties it sas: Video: qtrle, bgra, 1280x1024, 195585 kb/s, PAR 1280:1280 DAR 5:4, 29.59 fps, 30 tbr, 30 tbn, 30 tbc
whereas bgra stands for rgb + a.
Do you know of any lossy 32 bpp codecs? -
RGB 32 is the same as RGB 24 except it has an additional 8 bit alpha channel (usually used for transparency). Since you don't know that you probably don't have anything in the alpha channel and don't need to preserve it.
Almost all high compression codecs work in YUV with 4:2:0 chroma subsampling.
https://forum.videohelp.com/threads/294144-Viewing-tests-and-sample-files?p=1792760&vie...=1#post1792760
I don't know of any high compression codecs that work in RGB. Lagarith or MSU lossless can compress in RGB but they're lossless and don't give a lot of compression unless your video has very little detail, or a very small frame size.
PicVideo MJPEG supports YUV 4:4:4 (they call it 1:1:1).
If you don't mind YUV 4:2:0 (as is usually used in MPEG 2) you can get more compression with h.264.Last edited by jagabo; 12th Dec 2011 at 20:45.
(FYI, h.264 supports this, and x264 can encode RGB, Y'CbCr 4:2:0, 4:2:2, 8 or 10-bit now , and FFMpeg can decode the output . But very few devices or even software yet support, basically only FFMpeg and some versions of Mainconcept AVC decoder)
But rarely do you need to preserve the alpha for a final distributable output format. The exception would be flash ads like banners on webpages.
You usually only need alpha for intermediates, for compositing in other programs. Most players won't even see the alpha. It will be displayed as black instead of transparent
The only common lossy distributable format that preserves alpha is vp6a, used in flv flash files. This is Y'CbCr 4:2:0 subsampled + Alpha . The alpha is visible in flash player => so you see the transparency instead of "black"
Animation codec, the file you are using is essentially uncompressed if used at the highest quality setting. Other options for RGB+A are png (e.g. png in mov) , lagarith, ut video codec
Yo Videohelperee. You have been disassembled.
Tell us again what you want in simple language. The solutions are probably simple.
Start with source format, then explain what you want from there.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 01:17 -
Recommendation of Lossy to lossy format(WMV/AVI/MKV to H264) via X264.
By xjohn in forum Video ConversionReplies: 6Last Post: 17th May 2011, 22:27 -
8-bit color RGB versus 10-bit color 4:2:2
By fouronthefloor in forum Capturing and VCRReplies: 4Last Post: 9th Oct 2010, 06:20 -
I have a 64bit system, to encode files do i need 64 bit codecs?
By shadowofanubis6 in forum Newbie / General discussionsReplies: 5Last Post: 1st Mar 2010, 10:24 -
Making 32-bit VFW-ACM codecs available to XP 64-bit Edition.
By gastorgrab in forum EditingReplies: 5Last Post: 19th Aug 2007, 11:12
