Two of a few .mov clips I shot on my ipod touch are upside down and one is sideways when I try to edit in Magix Movie Edit Pro 17. They play correctly in Quicktime and VLC. When I try to convert in VLC to see if that turns them right side up for edit it crashes the program. I have tried converting to other formats such as wmv but that file runs upside down in WMP and VLC.
Anyone know of a way to set the orientation in Magix or know of a program that will convert the clips to the proper orientation?
Thanks,
Richard
Well .... I figured it out. Convert clip to wmp then open that clip in Windows live movie maker, flip it and and save. Damn I hate it when with using MS stuff is the fix.
Magix Movie Edit Pro 17 - Help
By volotre in forum EditingReplies: 1Last Post: 12th Apr 2011, 12:27 -
Magix Movie Edit Pro 17 for .mts
By Buckskin in forum Video ConversionReplies: 0Last Post: 2nd Oct 2010, 15:51 -
MAGIX Movie Edit Pro 12 problem
By Rein Engel in forum EditingReplies: 0Last Post: 21st Sep 2007, 14:40 -
Magix Movie Edit Pro 11 Encoder
By SCDVD in forum EditingReplies: 0Last Post: 7th Jun 2007, 18:09 -
question about magix movie edit
By sd001 in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2007, 04:55
