Hi, Ok Im a little stuck on this one . Ive been learning how to encode with the latest version of MeGUI but cant for the life of me find how to passthrou the Audio instead of encoding it?. I would be very grateful if some learnered person could direct me. Many thanks as always.
The only thing I can find on the subject is from the MeWiki:
http://mewiki.project357.com/wiki/Guides/Basic_Guide
Where it states: 5.1 audio (if you want to do this, I would recommend muxing the original ac3 file and not doing any encoding).
Surely theres an easier way rather than having to demux the original audio and then muxing it manually to the video? -
Hi, I am getting to grips with MeGUI myself. The way that works for me is to use the one click encoder option,
- select your input file
- check the advanced options box
- select the encoder config tab
- change the encode audio option to never
- click GO
the video will get encoded then muxed with the original audio to create your new output.
hope this helps! -
Thanks Harpon, I actually discovered that way of doing it but I need to adjust the deinterlacing parameters which is only available when you encode via > Tools/File Indexer or Tools/AVS Script Creator....
Yeah can't see an easy way using the manual way apart from the audio already been demuxed when the input file is indexed as you probably have already found.
- index
- encode video
- then tools/muxer select encoded video + original audio and mux
Anyone else? -
I have found another work around, after indexing the file it demuxes the audio into ac3 file untouched(I think), now on the input tab under audio click the "X" to clear the track details, now AutoEncode and Select the ac3 file that I think is untouched under add other tracks.... bit long winded I know, thats why Im thinking there must be an easier way. This is the only way to do it through the File Indexer and AVS Script Creator.... Next question is how on earth do you Queue all this up so you can do 10 at a time without coming back to index the files or stuff??.
Anyway Merry Xmas Harpon, let me know if you have any success or discover anything else
MeGUI audio encoding dts/ac3 to aac-mp4, keep getting errors
By runLoganrun in forum AudioReplies: 5Last Post: 29th Jul 2010, 17:15 -
DTS to AAC in MEgui
By kadyn67 in forum AudioReplies: 2Last Post: 22nd Jun 2010, 00:04 -
Reauther dvd with pcm & dts to ac3 & dts
By djblade in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2010, 08:40 -
How do I add AC3 'and' AAC to my video files created using meGUI?
By sangood in forum Blu-ray RippingReplies: 11Last Post: 2nd Jan 2009, 15:27 -
MEGUI support for DTS?
By user12345 in forum AudioReplies: 0Last Post: 22nd Dec 2008, 02:03
