Ok I have a few MTS files that need Sorting Im desperate
I saved them on my computer But I already knew they were damaged but saved them anyway
Majority of them work thats fine but final I think about 10 dont import or play or anything
File size file name is, I just cant fix them. Been online down loaded a lot of software
but there all taking about recovering data from card... thats now what I want.. I already hav the Files
I just wanna play them even if it fixing them on low quality
The video camera i was using was Sony NEX-FS100
any help would be Awesome Thanks in advance guys
Results 1 to 11 of 11
Hi Davexnet
thanks for your quick reply
I Tried that GDSMUX software doesn't allow you to add MTS file as a Source but allows it when you try adding it as an attachment.
It does make an MKV file but bascially does nothing
Below is the info of mediainfo file Iv copy and pasted 2 the first one is the corrupted file and the 2nd one is a correct file so you can see the
difference in file and information... One again thanks for trying to help me out mate..
THIS IS FROM A FILE THAT IS CORRUPTED
Count : 278
Count of stream of this kind : 1
Kind of stream : General
Stream identifier : 0
Inform : 86.9 MiB
Complete name : H:\DRIVE A\DURESH SHAMA\Duresh\CARD\PRIVATE\AVCHD_BK\BDMV\STREAM\000 00.MTS
Folder name : H:\DRIVE A\DURESH SHAMA\Duresh\CARD\PRIVATE\AVCHD_BK\BDMV\STREAM
File name : 00000
File extension : mts
File size : 91164672
File size : 86.9 MiB
File size : 87 MiB
File size : 87 MiB
File size : 86.94 MiB
Stream size : 91164672
Stream size : 86.9 MiB (100%)
Stream size : 87 MiB
Stream size : 86.94 MiB
Proportion of this stream : 1.00000
File creation date : UTC 2011-12-05 13:56:39.556
File creation date (local) : 2011-12-05 13:56:39.556
File last modification date : UTC 2011-09-29 23:09:38.000
File last modification date (loc : 2011-09-29 23:09:38.000
THIS IS FROM A FILE THAT IS WORKING
General
Count : 278
Count of video streams : 1
Count of audio streams : 1
Count of text streams : 1
Video_Format_List : AVC
Video_Format_WithHint_List : AVC
Codecs Video : AVC
Audio_Format_List : PCM
Audio_Format_WithHint_List : PCM
Audio codecs : PCM
Text_Format_List : PGS
Text_Format_WithHint_List : PGS
Text codecs : PGS
Complete name : H:\DRIVE A\DURESH SHAMA\Duresh\CARD\PRIVATE\AVCHD\BDMV\STREAM\00003. MTS
Folder name : H:\DRIVE A\DURESH SHAMA\Duresh\CARD\PRIVATE\AVCHD\BDMV\STREAM
File name : 00003
Format : BDAV
Format : BDAV
Format/Info : Blu-ray Video
Format/Extensions usually used : m2ts
Commercial name : BDAV
Codec : BDAV
Codec : BDAV
Codec/Info : Blu-ray Video
Codec/Extensions usually used : m2ts
File size : 74440704
File size : 71.0 MiB
File size : 71 MiB
File size : 71 MiB
File size : 70.99 MiB
Duration : 24396.697333
Duration : 24s 397ms
Duration : 00:00:24.397
Overall bit rate mode : VBR
Overall bit rate : 24405307
Overall bit rate : 24.4 Mbps
Maximum Overall bit rate : 24000000
Maximum Overall bit rate : 24.0 Mbps
Stream size : 3087932
Stream size : 2.94 MiB (4%)
Stream size : 3 MiB
Stream size : 2.9 MiB
Stream size : 2.945 MiB
Proportion of this stream : 0.04148
File creation date : UTC 2011-12-05 13:55:02.184
File creation date (local) : 2011-12-05 13:55:02.184
File last modification date : UTC 2011-09-29 23:26:54.000
File last modification date (loc : 2011-09-29 23:26:54.000
Video
Count : 205
Kind of stream : Video
Menu ID : 1
Menu ID : 1 (0x1)
Format : AVC
Format/Url : http://developers.videolan.org/x264.html
Commercial name : AVC
Format profile : High@L4.0
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 2
Format settings, ReFrames : 2 frames
Format settings, GOP : M=2, N=13
Internet media type : video/H264
Codec ID : 27
Codec : AVC
Codec : AVC
Codec/Family : AVC
Codec/Info : Advanced Video Codec
Codec/Url : http://developers.videolan.org/x264.html
Codec profile : High@L4.0
Codec settings : CABAC / 2 Ref Frames
Codec settings, CABAC : Yes
Codec_Settings_RefFrames : 2
Duration : 24360
Duration : 24s 360ms
Duration : 00:00:24.360
Bit rate mode : VBR
Bit rate mode : Variable
Bit rate : 21892037
Bit rate : 21.9 Mbps
Maximum bit rate : 21999616
Maximum bit rate : 22.0 Mbps
Width : 1920
Width : 1 920 pixels
Height : 1080
Height : 1 080 pixels
Pixel aspect ratio : 1.000
Display aspect ratio : 1.778
Display aspect ratio : 16:9
Frame rate : 25.000
Frame rate : 25.000 fps
Frame count : 609
Resolution : 8
Resolution : 8 bits
Colorimetry : 4:2:0
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8
Bit depth : 8 bits
Scan type : Interlaced
Scan order : TFF
Scan order : Top Field First
Interlacement : TFF
Interlacement : Top Field First
Bits/(Pixel*Frame) : 0.422
Delay : 1120.000
Delay : 1s 120ms
Delay : 1s 120ms
Delay : 1s 120ms
Delay : 00:00:01.120
Delay, origin : Container
Stream size : 66661252
Stream size : 63.6 MiB (90%)
Stream size : 64 MiB
Stream size : 63.57 MiB
Proportion of this stream : 0.89549
Buffer size : 24000000 / 24000000
Audio
Count : 173
Kind of stream : Audio
Menu ID : 1
Menu ID : 1 (0x1)
Format : PCM
Commercial name : PCM
Format settings : Big / Signed
Format settings, Endianness : Big
Format settings, Sign : Signed
Muxing mode : Blu-ray
Codec ID : 128
Codec : PCM
Codec : PCM
Codec/Family : PCM
Codec settings : Big / Signed
Codec settings, Endianness : Big
Codec settings, Sign : Signed
Duration : 24435
Duration : 24s 435ms
Duration : 00:00:24.435
Bit rate mode : CBR
Bit rate mode : Constant
Bit rate : 1536000
Bit rate : 1 536 Kbps
Channel(s) : 2
Channel(s) : 2 channels
Channel positions : 2/0/0.0
Sampling rate : 48000
Sampling rate : 48.0 KHz
Samples count : 1172880
Frame count : 1172880
Resolution : 16
Resolution : 16 bits
Bit depth : 16
Bit depth : 16 bits
Delay : 1040.000
Delay : 1s 40ms
Delay : 1s 40ms
Delay : 1s 40ms
Delay : 00:00:01.040
Delay relative to video : -80
Delay relative to video : -80ms
Delay relative to video : -00:00:00.080
Video0 delay : -80
Video0 delay : -80ms
Video0 delay : -00:00:00.080
Stream size : 4691520
Stream size : 4.47 MiB (6%)
Stream size : 4 MiB
Stream size : 4.5 MiB
Stream size : 4.474 MiB
Proportion of this stream : 0.06302
Text
Count : 139
Kind of stream : Text
Menu ID : 1
Menu ID : 1 (0x1)
Format : PGS
Commercial name : PGS
Codec ID : 144
Codec : PGS
Codec : PGS
Duration : 23855
Duration : 23s 855ms
Duration : 00:00:23.855
Delay : 1040.000
Delay : 1s 40ms
Delay : 1s 40ms
Delay : 1s 40ms
Video0 delay : -80
__________________________________________
I didnt know how much if this information i was ment to post so sorry abt that
Regards and thanks again SKY -
If you don't mind posting the video for further review, upload the good and the bad to mediafire.com
and put the URL's in here. Myself and others will take a look. -
Here you go Davexnet
2 files here one working one with problems
Something very interesting happened
While I zipped the Corrupted file.. The file size Shrunk too an extremely small size
and when when I unzipped the file again the file went back to its 90MB or so
anyway Just have to warn you about the video
Its some really Bad Indian Wedding Dancing lol
anyway its the smallest size footage i cud get of each file
https://rapidshare.com/files/788226169/corrupt.zip
https://rapidshare.com/files/2662920870/working.zip -
Because the file shrunk so much in zipping it means its missing a lot of data so it cant be fully fixed.
Here is the unzipped file version, hopefully this will help
Regardless if this problem is solved or not I really really appreciate you guys trying to help me
I cant thank you enough Seriously
SKY
link below is of the Not zipped version of the corrupted file above
https://rapidshare.com/files/3133064781/00000.MTS -
There's nothing in the mts file,it zips to 80kb meaning there's nothing in there to salvage.
AS was alluded to, the corrupt file contains nothing except x'00''s all the way through. It's worthless.
If you want to check it out your self, open Virtualdub/tools/ hex editor and load the file. -
Yeah I uploaded the file again above but Iv put the file here again here
without it being zipped
Well I did download it again, and the zip file posted earlier was a true representation. The file contains nothing except binary zeroes.
As I mentioned, you can look at it yourself and see. Assuming you haven't reused the camera, perhaps try a different recovery program? recuvu, for example.
http://www.piriform.com/recuvaLast edited by davexnet; 14th Dec 2011 at 12:12.
How to merge multiple .mts files (canon HF) into one single .mts file
By frmsuv2van in forum Video ConversionReplies: 15Last Post: 5th Sep 2014, 21:21 -
Problem with MTS HD-file from Sony and downscaling to SD
By TSPreben in forum Video ConversionReplies: 3Last Post: 27th Apr 2012, 02:59 -
Problems reading .mts files (possibly corrupted)
By moxiecat in forum Video ConversionReplies: 24Last Post: 7th Mar 2011, 13:35 -
Corrupt .mts file problem - length too short
By nlmts in forum Video ConversionReplies: 0Last Post: 2nd Aug 2010, 17:16 -
Big problem (file corrupted)
By abdelilah in forum Video Streaming DownloadingReplies: 5Last Post: 22nd Jan 2009, 15:38
