I just burned a set of home video clips (mp4 files) on a 2x Verbatim BD-RE disc.
I used ASUS BW-12B1ST and Cyberlink power2go for the task.
The disc is burned as a data disc with UDF file system.
My samsung BD-C6900 player just cannot load the disc even though BD-RE disk is list on samsung website's spec.
Forgot to add that the data disc can be accessed fine on the desktop from the burner, so it was burned successfully.
Does anyone have any insight?
Which UDF file system did you use? I do not recommend anything above 2.50.
BD data disc file play may not be supported so the problem may not be the disc but the fact that it's not BluRay format.
My Momitsu BluRay player refuses to play anything on my Sony BD-RE disc and I suspect that it just doesn't like BD-RE discs. I just last night bought a cheap Verbatim BD-RE disc but I haven't tested it yet. I can't rule out the possibility that BD-RE discs are just different enough from BD-R that some players may simply have problems with them. -
The specs say nothing about the unit being able to play DATA files burned to a BD-RE disc.
http://www.samsung.com/us/video/blu-ray-dvd/BD-C6900/XAA-specs
How to shrink a 50GB-BLURAY-movie to fit on a 25GB-BLURAY disc ?
By kulmagen in forum DVD RippingReplies: 31Last Post: 1st Feb 2012, 13:39 -
Samsung BR Player BD-C6900 AVCHD Play
By here2rock in forum DVD & Blu-ray PlayersReplies: 5Last Post: 25th Oct 2010, 18:21 -
How to put 15hours+ SD video into one 25GB Bluray disc
By kmnorya in forum Authoring (Blu-ray)Replies: 3Last Post: 5th Sep 2010, 05:04 -
Audio is skipping when I play videos that are burned on a Data disc DVD!
By Xenogear900 in forum Software PlayingReplies: 8Last Post: 23rd Mar 2009, 13:12 -
will a avi data disc play in a divx player?
By nobbyiscool in forum Newbie / General discussionsReplies: 2Last Post: 25th Jul 2007, 14:23
