I have a video that only vlc successfully opened by repairing it 1st. when I open the file, it pops up the dialogif I click repair button, the video will work fine FOR THIS SESSION ONLY, the repair is not saved onto the original video. I tried to open with avidemux or virtualdub and use their own repair function, but they couldn't open it. here's the media info, notice that the vlc is able to play both audio and video, and yet media info only shows video stream info.Code:this avi file is broken. seeking will not work correcting. do you want to try and fix it?wtf why can't I use space to separate my lines? in this thread?Code:Complete name : D:\video1.avi Format : MPEG-4 Visual File size : 1.46 GiB Video Format : MPEG-4 Visual Format profile : Advanced Simple@L5 Format settings, BVOP : 2 Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Custom Width : 640 pixels Height : 272 pixels Display aspect ratio : 2.35:1 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Writing library : XviD 1.1.2 (UTC 2006-11-01)
AnonymousGuest
Seeking opinions about my converted dv-avi file
By hygieneboy in forum Video ConversionReplies: 35Last Post: 28th Jan 2009, 18:26 -
How can i remove/fix some broken codecs?
By GangstaRap in forum Newbie / General discussionsReplies: 23Last Post: 23rd Feb 2008, 05:04 -
How to fix broken IFO?
By Hamilton in forum Authoring (DVD)Replies: 1Last Post: 24th Nov 2007, 04:16 -
how to fix broken mpg file?
By ecc in forum Video ConversionReplies: 4Last Post: 6th Oct 2007, 08:56 -
Seeking Guidance: Avi to DVD
By Dan36oy in forum Video ConversionReplies: 5Last Post: 4th May 2007, 10:09
