AVStoDVD is such a great program, it's frustrating when it can't complete a project. I have tried several times, with as many different settings, to try and complete a project but each time, the end result is the same; AVStoDVD stops at 95% completion. However, I can run the project in ConvertXtoDVD and all goes well except it lacks the Menu capabilities that AVStoDVD has.
What could ConvertXtoDVD be completing that AVStoDVD does not want to complete?
Attached is the log from the last uncompleted project run through AVStoDVD:
Results 1 to 17 of 17
there's a avs2dvd thread here somewhere...the author may be able to help you
offhand, it sounds like one of the files is corrupt -
Apparently, this is all the BatchMux log contained:
Segment memory resources --> RELEASED
Local Stack memory --> RELEASED
File i/o structures --> DEALLOCATED -
Check out this thread. Some dude received the same error and it was due to some bad blocks (write error) on his HDD.
Have you tried running a disk check ?
http://forums.afterdawn.com/t.cfm/f-126/avstodvd_muxman_problem-881704/ -
I ran chkdsk and all seemed well. I'm really at a loss for this. I re-ran the project and again, the completion stops at 95%.
Batchmux log just contains nothing but what I previously wrote.
Any ideas? -
Using a dvd-rw, I'd start removing the clips towards the end one by one and see if it completes the operation. This is often the only way to determine what it's hitting when it stops.
I think I'll just abandon AVStoDVD and utilize a different Authoring program. When I have problems with AVStoDVD, I generally use ConvertXtoDVD which is successful 100% of the time BUT, it lacks Menu building capabilities.
Any recommendations for another all-in-one converter with two pass encoding capability that also has Menu building capabilities that they've have success with? -
Perhaps give AVI2DVD a try:
http://www.trustfm.net/divx/SoftwareAvi2Dvd.php?b2=1
Just out of interest, I noticed the version of muxman.exe included in AVStoDVD is version 15,
while the version available for download from videohelp.com/tools is 16.8.
I gave it a try (just replaced the version in \program files\avstodvd\muxman)
and it seems to work, however, I've got no idea why MrC left in the old version -
there may be a good reason. -
Well, same result, stops at 95% completion. And I can't figure out why I get almost nothing in the Batchmux log:
This just doesn't make sense. -
SUCCESS! Creating a Output folder in my 2nd HD seemed to do the trick as I have a 100% completion. Am curious as to why I couldn't use the working HD. Thank you Dave and MrC. I feel like I just rebuilt a mainframe!
Dave, yes, I did. I tried both deleting and keeping but I just couldn't get anything more in the log. Must be something I have configured elsewhere which is incompatible.
Very interesting - I've used to do it on the main drive, never had a problem like this.
I find having the assets on one drive and author to another runs much faster at that step.
Glad to hear it's fixed!
AVStoDVD ERROR DURING OPERATIONS ('DVD Authoring operations' Section): 0
By avitodvdbabe in forum Authoring (DVD)Replies: 0Last Post: 22nd Oct 2011, 16:14 -
Complete Authoring Package please?
By 1RealNewbie in forum Authoring (DVD)Replies: 3Last Post: 28th Sep 2009, 07:09 -
AVStoDVD!
By Milardo in forum Authoring (DVD)Replies: 12Last Post: 15th Feb 2009, 05:01 -
DVD authoring fails - 'error in parsing XML'.
By Levina in forum ffmpegX general discussionReplies: 12Last Post: 22nd Mar 2008, 09:10 -
dvd burn fails in all software authoring programs
By jfrenchu in forum Authoring (DVD)Replies: 8Last Post: 9th Feb 2008, 22:39
