Can anyone help me to select a blu ray player that will play recorded dual layer blu ray discs? I have tried LG and dynex players with very limited success. Single layer recorded blu ray discs play fine. Thanks.
Recorded how? The point being, some players (my Sony BDP-S360s, for example) are rather forgiving. Others will require strict compliance to BD requirements.
Anyway, a quick search of standalone players listed over <--- there, and filtering for BDR-DL, yields this:
https://www.videohelp.com/dvdplayers?DVDname=&bdrdl=1&Search=Search&orderby=Name&hits=5...Submit2=Search
[EDIT] And welcome to the forum.Pull! Bang! Darn! -
"Recorded" is absolutely the wrong word for what you have. You want to say something like "consumer burned" instead to accurately describe your situation.
Some players are fussier than others. The ONLY Blu Ray DL media I would trust is that made by Verbatim. Using other brands may cause playback problems.
I have a Momitsu Blu Ray player that plays BD-R DL discs OK most of the time, but it just barfs on BD-RE discs. BD-R DL discs should be supported, but again, use Verbatim to give yourself the best chance for success. Unfortunately you'll just have to test a player to see how it does.
Finally new 100 GB Blu Ray DL discs are showing up on the market now. You should NOT expect any current Blu Ray player to be able to play those without problems. -
Thanks. I have been using panasonic bd-r dl media purchased and manufactured in japan.
Unfortunately as I have found out "Made in Japan" does not necessarily equal "top notch quality" when it comes to BD media. Ritek BD discs are also "Made in Japan". I recently bought a set of 10 TDK "Made in Japan" ink jet printable single layer BD-R discs and I was PISSED to find out that they were made by damn Ritek. So far they seem OK but I'll never buy them again. TDK used to use Taiyo Yuden for it's Japanese media so I could have kicked myself for not checking prior to purchase who they are currently using instead of just assuming it would it be TY.
Isn't it true that all Blu-Ray players are required to play commercially mastered dual layer Blu-Ray discs? There are many out there for sale.
http://www.kiva.org/about -
Okay, i am confused.....
If you are using Dual Layer Bluray media, why would you need to use BD Rebuilder ?
I'll Ignore the "recorded" comment for now......
LOL!!!
BDR-206 and Taiyo Yuden
By ccarag in forum DVD & Blu-ray WritersReplies: 20Last Post: 2nd Oct 2011, 12:54 -
Problems with BDR in a PS3 Slim - Please help!
By robbalvey in forum Authoring (Blu-ray)Replies: 3Last Post: 30th Aug 2011, 06:47 -
What bluray player to get for MKV/MP4 from BDR?
By narcispy in forum DVD & Blu-ray PlayersReplies: 2Last Post: 26th May 2011, 09:13 -
MultiAVCHD mkv to 25gb bdr
By VOYAGER2009 in forum Authoring (Blu-ray)Replies: 4Last Post: 25th Apr 2011, 09:37 -
BDR produced on a 4.6 GB file...fritzi?
By New Bee in forum Blu-ray RippingReplies: 9Last Post: 4th Feb 2011, 11:38
