I have Mac OS X and need help with....
Converting DTS and Dolby Digital AC3 to .WAV files to convert into whatever I want using Compressor. Eac3 and all that other software sounds great but its all Windows...any solutions? I have been using handbrake and encoding using the lowest video settings but I would prefer not to have to do that >![]()
Consider PMing a mod to ask to move your post to the Mac forum, which might provide more expert help.
However, since none of the Mac users on this forum have found your post yet, I'll do my best to help, based on what I have seen in other forum posts. ffmpegx is low-cost GUI trialware for OSX that appears to be able to convert to and from a fair number of audio codecs. ffmpeg is a free command line tool that is also able to convert to and from a good number of audio codecs. -
Hmm okay thanks sounds good! I am most definitely willing to pay low to moderate cost for software if it provides versatility. Are their any DTS or DD TrueHD encoders on the cheap (available by other means of course
)? I have allot of DVD's that I own and the quality never does them justice with my HD tv's and audio decoders so I usually find the BluRay rips which have incompatible audio formats at times...for example I come across allot of 6 channel and even 8 channel AAC files that my decoder just down mixes to Dolby Digital Pro Logic IIz instead of DD 5.1 or DTS 6 channel discrete...
Thread moved to mac forum and please do not ask for help on obtaining warez apps.
Hi.
http://www.angelfire.com/mac/rnc/files/MoreTools.html
MoreMissingTools will do the job you want on most VOB files demuxed into video codec audio and video files.
http://www.macupdate.com/app/mac/17157/aiff-from-pcm
AIFF from PCM, costing 99 cents from the App Store, will convert DVD uncompressed audio into Apple's AIFF audio format, which is the Mac equivalent of WAV.
You might also need Perian, YadeX, and MPEG Streamclip - well, you would if you wanted the same suite of audio/video play tools I use. And very likely the Quicktime MPEG2 Playback component from Apple (which they charge for).
YadeX will demux unencrypted DVDs into 'source' format video and audio files; MPEG Streamclip will give you multiple demux options from unencrypted DVDs.
Enjoy... I hope,
Michael
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 06:04 -
Capturing VHS to Mac via Panasonic AG-1980 and ATI 650 USB Mac
By Stu187 in forum Capturing and VCRReplies: 3Last Post: 15th Aug 2010, 06:45 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 06:18 -
im new to mac... is there a mac program that does what tmpgenc dvd author 4
By ochsfamily in forum MacReplies: 0Last Post: 12th Dec 2009, 23:13
