Can i write single files into a DVD larger than 4 Gb? Do i have to use UDF for this? I read Joliet supports maximum 4 Gb, what about UDF?
UDF supports files over 4 GB, up to 16 EiB . Some devices may not be able to handle them though.
UDF v1.50-v2.60 have a rediculously high limit(??Exabytes), so nothing to worry about there.
UDF 1.02, OTOH, because it has to remain compliant with the DVD-Video and DVD-Audio specs, requires that ALL files be <1GB (this is often relaxed when not in the VIDEO_TS or AUDIO_TS zones).
Of course, if you're talking about spec DVD-Video, it HAS to be <1GB, or isn't legal/compliant (and likely unplayable by MOST players).
...too slow on the draw again...
Changing Record Date. Canon S30 AVCHD Files
By Obtong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 25th Nov 2011, 00:36 -
File structure of UDF-ISO image files
By Waly in forum ProgrammingReplies: 5Last Post: 21st Oct 2010, 09:44 -
Burning with UDF
By gooberguy in forum Authoring (Blu-ray)Replies: 9Last Post: 18th Jul 2009, 17:01 -
Use DVD recorder to record to end of video_ts files
By aeafisme23 in forum Authoring (DVD)Replies: 1Last Post: 4th May 2008, 17:53 -
VOB files - Video _ TS folder wont record dts codec on toast 7
By BattyRoy in forum MacReplies: 8Last Post: 10th Apr 2008, 00:30
