  1. Can somebody tell me what is the combination to create a column from one to 1-100, without introducing it manually?
    Here is what I mean:
    Uploaded with ImageShack.us
    Thanks in advance!
  2. Do you mean autofill the value "1" from rows 0-100 in column 1?
    Select the cells, you only need 3 filled in with "1" for it to work (i.e marquee select the area ) , then move cursor to bottom right hand corner of that selection area, a "plus" sign will appear, hold left click and drag all the way down to row 100
    It will autofill patterns too. So if you had 1,2,3 , it will fill in 4,5,6, etc...
  3. Originally Posted by poisondeathray View Post
    Thank you very much!
    Cheers!
