Hi everyone i have a avchd disc i created with avchdcoder and it plays fine on my bd player, the problem is that i gave a copy to my friend that has a samsung BD-D5100 and format is not supported appears on the screen, is it possible to use tsmuxer on the m2ts file to create a blu-ray disc instead of avchd disc?
Results 1 to 12 of 12
i'd try multiAVCHD
http://www.kiva.org/about -
it was a DVD+R DL and this method didn't work, it's still saying format not supported when he insert this disc in the player, i also notice that after i ran the .m2ts file with Tsmuxer in the file properties still says AVCHD Video??
any other suggestions??
Thanks. -
Does your player spec say it is AVCHD disc compatible?
AVCHD @ 17 Mb/s is the spec for "AVCHD disc". Many players will go higher (spin disc faster than 2x).Recommends: Kiva.org - Loans that change lives.
I looked up the Samsung BD-5100 and it does not mention AVCHD playback. If it doesn't support AVCHD it's unlikely to support BR playback from DVD disks of any kind. You probably need to put it on a BR blank for your friends player.
AVCHD on hard drive: creating new AVCHD folder structure
By Phil_W in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st May 2011, 14:46 -
AVCHD from SD-60
By domyue in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 4th Dec 2010, 14:02 -
software to batch convert m2ts format avchd to mts avchd?
By masterpug in forum Video ConversionReplies: 0Last Post: 14th Aug 2010, 01:06 -
Avchd
By cabletangle in forum Newbie / General discussionsReplies: 3Last Post: 7th Aug 2010, 10:13 -
new to AVCHD
By coeng73 in forum Newbie / General discussionsReplies: 8Last Post: 28th Jul 2009, 14:28
