I have a few 24 fps mpg that were made with a webcam. I need to pixelate someone out of them and have a demo copy of Magix Movie Ed Pro 17 that I can do that with.
The problem when i import the clips into magix it shortens them significantly and speeds the action way up.
This also happens when I convert to mp4 using AnyVideo Converter even though I can set the frame rate to 24 fps as per options in the program.
Any idea how I can get around this problem? I don't want shorted clips or faster action but I need to hide this persons id.
Thanks,
MisterRPH
the orginial plays fine in media player and the edit which I exported as mp4 plays in quick time with faster action and shorter clip. I used the speed option in video affects and slowed it down to .63 when gets the fps rate down below 16 and lengthens the clip out to original time. Running the edit side by side with original and they look to be same rate.
I don't see any menu option named mediainfo.
Thanks for your response. -
The video clip I got when I exported the Video Effects slowed down edited version of my original clip is intolerably jerky but does appear to run at near the same speed as the original. Is there some way to smooth it out?
I installed the Mediainfo program and got the following info about my original clip. If it tells you there is a better way for me to obtain the results I want I would appreciate you telling me how to proceed.
Thank You very much for your assistance!!!
General
Complete name : K:\Video2.mpg
Format : MPEG-PS
File size : 86.2 MiB
Duration : 6mn 21s
Overall bit rate : 1 894 Kbps
Writing library : ArcSoft MPEG-1 NTSC
Video
Format : MPEG Video
Format version : Version 1
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Duration : 6mn 21s
Bit rate : 1 633 Kbps
Maximum bit rate : 1 500 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 24.000 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.221
Stream size : 74.3 MiB (86%)
Audio
Format : MPEG Audio
Format profile : Layer 2
Duration : 6mn 21s
Bit rate mode : Constant
Bit rate : 224 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 10.2 MiB (12%) -
Probably your editor has problems importing the file if it plays fine in a media player (clip is probably ok, but editing software not compatible)
If you open the file in avidemux, does it play correctly? If it does, then encode to another format your editor supports using that
Maybe a lossless format like huffyuv/AVI
If VLC plays it correctly, it can convert as well, so you could use that to convert, then import into your editor -
Well the clip ran fast in avidemux until I slowed it down by reducing the frame rate there. Next I downloaded VLC and the original clip played fine there so I converted it to mp4 and the mp4 plays like the original too. I loaded the mp4 into Magix Edit Movie and it appears to have chopped off about 15 seconds but as near as I can tell the speed it the same as the original. Now all I have to do is do all my masking again and see how it saves...lol
Thank you very very much for hanging in with the novices novice. I will post at least one more update to let you know it this thing exports ok.....thanks again!! -
It took near 12 hours render the edited mp4 clip. I learned that converting the original mpg to wma format gets me a clip of the same length and playback speed and the original and that clip edited renders in about an ours.
Trouble converting 25FPS MKV file to 24FPS
By dave in or in forum Video ConversionReplies: 3Last Post: 29th Jul 2011, 22:46 -
subtitles 25fps, video 24fps both synchronized - converting to DVD, a mess
By Ze Tomes in forum SubtitleReplies: 10Last Post: 27th May 2011, 01:45 -
The length of video remains the same as original after splitting
By Moth Queen in forum EditingReplies: 1Last Post: 25th May 2011, 08:26 -
How to retain 16:9 when converting to Huffyuv?
By brassplyer in forum EditingReplies: 3Last Post: 25th Apr 2010, 08:15 -
Is it possible to retain HD Audio when converting to BD9 in BDREBUILDER
By igotafeelin in forum Authoring (Blu-ray)Replies: 4Last Post: 12th Aug 2009, 16:42
