I try to convert 1st DivX AVI (which plays ok in wmp and others)
with help from "DivX to VCD All-In-One Guide".
After the AVI is loaded in VirtualDub I get File Info:
AVI Information, Video Stream: Frame size 384x288 25fps,
Audio stream 48kHz, Stereo, Sample precision 0-bit,
Compression: Unknown (tag 0055).
When I click File-Save WAV I get the error:
"VirtualDub Error: The requested audio compression is not
compatible with the input format. Check that the sampling
rate and channel count of the input match those of the
requested format."
Anyone an idea where it goed wrong?
Thanks,
Jaap van Geels.
hy
attention to the 1ērule to VCD
video at 1150kbps
audio at 224 kbps / 44.1 khz
to convert a divx/avi file to vcd i use the TMPeg with the template VCD PAL and it works
to me the virtualdub needs experience to work with it
2man
Is there a way to save a Virtualdub filter chain?
By groove365 in forum Capturing and VCRReplies: 5Last Post: 3rd Sep 2010, 23:20 -
VirtualDub....save as .mp4
By Ogilvy in forum Video ConversionReplies: 2Last Post: 19th Mar 2010, 23:29 -
Isolate Audio In This MPEG-2 File, And Save As WAV (or any other format)
By onesikgypo in forum AudioReplies: 0Last Post: 22nd Feb 2009, 04:14 -
Can VirtualDub save DV-AVI's?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 21st Oct 2008, 09:10 -
VirtualDubMod and Save WAV problem...
By bla4free in forum AudioReplies: 7Last Post: 9th Oct 2008, 15:53
