I want to make a mini mkv file, i got amagai ss 821mb episode 1, i want to make it 100mb mini mkv. What program should i use to make it mini mkv file?
				Results 1 to 29 of 29
	A video editor, leaving you only the opening and closing credits?
	i want to decode it to 100mb, but i got told by my friend to make a the bitrate smaller.
	CHEERS GARRY
	Thank's jagabo
 Does anybody know What 8bit/10bit (Mentioned in some anime mkv files) is??
 Like this one: Sakurasou no Pet na Kanojo [10-bit, 720p]
	8 vs 10 bit is the bit depth of each video channel (Y, U, V). 10 bits gives smoother gradients but many computers and most standalone players cannot play it.
	it specifies whether x264 with 10bit precision or 8bit precision is used. (It has nothing to do with the color space that is used.)
 current x264 build can be found over at: http://komisar.gin.by/
	I thought 8 bit vs 10 bit was the size of the number they use to 'fill in' each 16x16 square. 8 bit would give 256 possible combinations, 10 bit would give 1024. I figure somehow they blend numbers to get more precise results. I'd loved to be corrected, I actually do wonder about this occasionally.
	There's no such thing as 43! And there's no such thing as a Mini MKV, so there's no way to make one. There are MKVs and that's that. If you want to know how to take an MKV and make a smaller version we'll tell you, but please don't throw buzz words at us.
	It's the number of bits used to represent each sub-channel of a YUV or RGB pixel. For example 8 bits of red, 8 bits of green, 8 bits of blue, a total of 24 bits for the entire pixel. You are right that 8 bits can represent 256 different values, 10 bits can represent 1024 different values. Take a greyscale image (the Y channel in YUV) for example: 8 bits can represetnt 256 different shades of grey (from full black to full white). 10 bits gives you 1024 shades of grey. So 10 bits can achieve smoother gradients.
 https://en.wikipedia.org/wiki/Pixel#Bits_per_pixel
 https://en.wikipedia.org/wiki/Pixel#Subpixels
	Riiiight, it didn't make sense that you could encode 8-bit videos in a 10-bit encoder until I thought about it. So it does a colour conversion from 8-bit to 10-bit, compresses in 10-bit (and is therefore able to get closer to the original colour without needing to get it exactly) then on playback it's converted back to 8-bit, and if it's converted properly banding and such is reduced...
  How do i make bleach 480 to mini mkv?By brotherhood1997 in forum Newbie / General discussionsReplies: 2Last Post: 7th Dec 2011, 14:43
  What would make a mkv file (x264) play or not on a Media Jukebox?By Christophe Lambert in forum Blu-ray RippingReplies: 6Last Post: 2nd Feb 2011, 19:29
  Improving the conversion of a .mkv file (DTS) to a .mkv file (AC3). Ideas?By mdelisle1 in forum Video ConversionReplies: 11Last Post: 19th Jan 2011, 11:50
  How to make chapters with a mkv file?By neworldman in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 18:18
  Noob: Is it possible to make subtitiles from MKV file?By peggypwr1 in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2009, 02:17
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
