Greetings! This is my first post.
Yesterday Nintendo put an update for the 3DS allowing to capture 3d Video with the console.
Checking the file we see that it uses 2 MJpg streams and a audio stream.
I was testing around and I can get 2 video stream at the resolution and the framerate, but I searched without any luck how to mux them in a single avi file.
Anyone know how to do it?
Tried that but I think it didnt work
Code:General Complete name : \test1.avi Format : AVI Format/Info : Audio Video Interleave Format profile : OpenDML File size : 13.2 MiB Duration : 54s 250ms Overall bit rate : 2 043 Kbps Writing application : AVI-Mux GUI 1.17.8.3, Feb 16 201019:42:50 Video ID : 0 Format : M-JPEG Codec ID : MJPG Duration : 54s 250ms Bit rate : 1 967 Kbps Width : 480 pixels Height : 240 pixels Display aspect ratio : 2.000 Frame rate : 20.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bits/(Pixel*Frame) : 0.854 Stream size : 12.7 MiB (96%) Audio ID : 1 Format : ADPCM Codec ID : 11 Codec ID/Hint : Intel Duration : 52s 434ms Bit rate mode : Constant Bit rate : 64.0 Kbps Channel(s) : 1 channel Sampling rate : 16.0 KHz Bit depth : 4 bits Stream size : 418 KiB (3%) Interleave, duration : 227 ms (4.54 video frames) Interleave, preload duration : 256 ms Title : sound
VLC Screencap
I tried several muxers but without any luck.
I saw there is this ffmpeg command line muxer but i dont know how to use it. Im in windows, could that work?
Thanks for your answer. -
Until I finish my coding (or someone steps in to help), you'll have to make due with either the old AVIMux.exe (tricking it by adding the 2nd video as if it was audio) -although this only works for short files-, or by using GraphEdit to build your own muxing process.
Scott -
Thanks a lot Cornucopia1! That worked.
Using the video as WAV worked to mux the video but the file isnt recognized by the 3DS.
This is the video I created:
Code:General Complete name : D:\output.avi Format : AVI Format/Info : Audio Video Interleave File size : 26.1 MiB Duration : 54s 250ms Overall bit rate : 4 033 Kbps Video #1 ID : 0 Format : M-JPEG Codec ID : MJPG Duration : 54s 250ms Bit rate : 1 967 Kbps Width : 480 pixels Height : 240 pixels Display aspect ratio : 2.000 Frame rate : 20.000 fps / 20.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bits/(Pixel*Frame) : 0.854 Stream size : 12.7 MiB (49%) Video #2 ID : 2 Format : M-JPEG Codec ID : MJPG Duration : 54s 250ms Bit rate : 1 967 Kbps Width : 480 pixels Height : 240 pixels Display aspect ratio : 2.000 Color space : YUV Chroma subsampling : 4:2:0 Stream size : 12.7 MiB (49%) Audio ID : 1 Format : ADPCM Codec ID : 11 Codec ID/Hint : Intel Duration : 53s 504ms Bit rate mode : Constant Bit rate : 64.0 Kbps Channel(s) : 1 channel Sampling rate : 16.0 KHz Bit depth : 4 bits Stream size : 418 KiB (2%) Interleave, duration : 753 ms (15.07 video frames)
Code:General Complete name : K:\DCIM\101NIN03\HNI_0057_.AVI Format : AVI Format/Info : Audio Video Interleave File size : 6.45 MiB Duration : 10s 624ms Overall bit rate : 5 090 Kbps Video #1 ID : 0 Format : M-JPEG Codec ID : MJPG Duration : 10s 450ms Bit rate : 2 511 Kbps Width : 480 pixels Height : 240 pixels Display aspect ratio : 2.000 Frame rate : 20.000 fps / 20.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bits/(Pixel*Frame) : 1.090 Stream size : 3.13 MiB (49%) Video #2 ID : 2 Format : M-JPEG Codec ID : MJPG Width : 480 pixels Height : 240 pixels Display aspect ratio : 2.000 Color space : YUV Chroma subsampling : 4:2:0 Stream size : 3.22 MiB (50%) Audio ID : 1 Format : ADPCM Codec ID : 11 Codec ID/Hint : Intel Duration : 10s 624ms Bit rate mode : Constant Bit rate : 64.0 Kbps Channel(s) : 1 channel Sampling rate : 16.0 KHz Bit depth : 4 bits Stream size : 83.0 KiB (1%) Interleave, duration : 50 ms (1.00 video frame) Interleave, preload duration : 94 ms
One thing you ought to try is take a copy of something that originally CAME from the 3DS (that you know works with it), and demux it to the raw streams. Then REMUX it using the hack I suggested. Then see what is different between the files. That will be more telling of what might not be set right...
Scott -
Oh, someone beat me to it, it was with ffmpeg.
http://www.elotrolado.net/hilo_tutorial-convierte-cualquier-video-3d-en-el-formato-de-la-3ds_1707979
Thanks for your replies
Anyone here use 3DS MAX?
By Rudyard in forum ComputerReplies: 5Last Post: 25th Jul 2012, 13:53 -
3DS Max vs Maya vs Cinema 4D
By surferadi96 in forum EditingReplies: 7Last Post: 12th Feb 2012, 16:13 -
Help with importing tracking data from Boujou to 3DS Max.
By surferadi96 in forum EditingReplies: 3Last Post: 11th Feb 2012, 09:30 -
Nintendo 3ds slashes price to 169.99 usd
By yoda313 in forum Off topicReplies: 0Last Post: 31st Jul 2011, 08:35 -
Nintendo 3DS 3D-AVI?
By Blrock in forum Newbie / General discussionsReplies: 7Last Post: 30th Mar 2011, 07:48
