I wonder if anybody can guide me on how to frameserve from Premiere CS4 to MainConcept Reference 2.2.
I have been trying the Debugmode Frameserver but couldn't be successful. I have never done frameserving before, to be honest.
Thanks.
Well...basically I didn't know how to use it. Here is what I did.
Installed the Debugmode Frameserver.
After editing in Premiere, when I click on Export --> Media, it opens up Adobe Media Encoder. For format, I select DebugMode Frameserver. When I click OK and Start Encoding, it does nothing. The window just closes down.
Is it technically possible to frameserve between CS4 and MainConcept Reference? If so, then I am not doing it right.
Thanks. -
It should just minimize or so not to close, it waits for encoder to load it. Thats frame serving, Vegas gives MainConcept only frames it needs at a time.
You had to give it a name inside Premiere, say signpost.avi, that file has couple of kb, or much more if you write audio as PCM in frameserver window (good idea if you work with audio within Premiere, or you have more audio tracks).
Then load that signpost.avi into MainConcept reference.
If it rejects that file, try to load Avisynth script with your correct path to the signpost.avi, for example:
AviSource("C:\signpost.avi")
Remember video has properties as your Project properties inside Premiere , not parameters of your clip.
When encoding is finished go back to Premiere and stop serving. -
OK thanks both. Wil try as per the advice tonight.
This is something I didn't know. Thanks.Remember video has properties as your Project properties inside Premiere , not parameters of your clip
How to compress a video to 1MB/min with MainConcept Reference?
By Bob2267 in forum Video ConversionReplies: 7Last Post: 25th Aug 2011, 02:11 -
MXF with JPEG2000 codec in Mainconcept Reference
By lord25 in forum Video ConversionReplies: 1Last Post: 3rd Nov 2009, 10:34 -
Changes in Adobe Premiere CS4 not reflected in Encore CS4 Timeline
By Funky Monk in forum Authoring (DVD)Replies: 0Last Post: 23rd Oct 2009, 07:51 -
Mainconcept Reference - 2ch audio
By ranosb in forum Video ConversionReplies: 2Last Post: 11th May 2009, 07:10 -
multichannel audio in MainConcept Reference
By lord25 in forum AudioReplies: 15Last Post: 2nd Apr 2009, 16:03
