I am trying to burn an AVI file to DVD with 720 x 304 (2:35:1) settings but the encoded file come out elongated and distorted. Is there some way to lock the Video perimeter setting to keep it at its original aspect ratio when encoding to DVD ffmpeg settings? I have it set to 2:31:1 (keep height), but it still doesn't seem to work. Any help would be appreciated. Thanks.
Set video output aspect ratio to "DVD 16:9".
Set option Decode with QT. Set Letterbox.
Those settings would keep original aspect ratio like this: a 2.35:1 picture in a 16:9 frame.
(Depending on how the AVI was encoded, you may need to install Perian for "Decode with QT" to work correctly. In any case, Perian won't hurt anything, but will expand QuickTime's capability when needed, including when ffmpegX "asks" QuickTime to read the source file.)
Thanks for the information and I'm glad my post made sense. I will try that. I do have Perian installed so it should work fine with QT.
Nope.
https://www.videohelp.com/dvd#struct
Search for "Authoring a DVD".
Issues Burning MKV to DVD
By link_417 in forum Authoring (DVD)Replies: 10Last Post: 18th Jun 2011, 15:07 -
DVD Burning Issues
By stonesfan71 in forum Newbie / General discussionsReplies: 5Last Post: 14th Dec 2010, 21:25 -
Burning DL DVD Issues (Nero 8, Sony Encore and Ashampoo 8)
By JJ - Tampa in forum Authoring (DVD)Replies: 3Last Post: 14th Jul 2008, 22:43 -
DVD burning issues..............
By marine89052 in forum DVD RippingReplies: 5Last Post: 2nd Apr 2008, 23:56 -
Burning Music Video Disc Issues
By ryangfm in forum Authoring (DVD)Replies: 20Last Post: 29th Jun 2007, 07:13
