. . . to protect the computer. With Blue Screen briefly shown, the ever-popular memory dump, and an automatic reset. What are the likely or possible causes of this ? (List, please.)
Fortunately, it has not been happening that often or regularly. In the most recent example, the only open & running program was a game of FreeCell. (Ha -- this is probably going to hurt my winning %, which was hovering around 80%. But I was about to lose that game anyway.) At least it hasn't happened while I was encoding video . . . .
A boot-time scan with Avast-5 was run just an hour prior to this, and came up clean.
I'll run a Spybot check next.
Athlon X2 5600+ with 4GB Ram, XP SP3 that is up to date on MS fixes.
Results 1 to 21 of 21
When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form.
In no particular order:
1) software problem
2) hardware problem
http://support.microsoft.com/kb/315263 -
I've had this happen when disk drives were beginning to go bad for me.
Or an SSD drive. The OCZ forums are full of BSOD threads, two common denominators being old iffy firmware and incorrect setup/usage of the SSD. (Fingers crossed, I have two and no problems..yet).
Didn't you just build a new computer?
Not to be a wise guy, but supposedly all Free Cell games are theoretically winnable.
Pull! Bang! Darn! -
To me, that happened only once, and it was because of a wicked Epson printer driver
( stupid installer required
Is your system set for automatic recovery? If so uncheck that option and take a closer look at the blue screen which will stay on till your reboot. There is often a reference to what caused it. To disable automatic recovery, go to your 'Control panel>System>Advanced system settings>Startup and Recovery' and uncheck the 'Automatically restart' box. This BSOD may also tell you if it's a hardware or software error.
And if no help there, open up the PC and reseat all cards and connectors. Then pull out one of your RAM modules and try it again with one, then switch to the other module. Bad RAM can cause all sorts of problems, including BSODs. -
@jman98,
This is a brand new WD Caviar Blue HDD.
No, not me. You might possibly be thinking of a power supply I replaced recently . . . but that wasn't on this particular computer.
I think it may be more correct to think of them as a puzzle, where there is one (or maybe a couple) correct paths to take for the solution (all involving those moves you're allowed to make per the rules), but if you take a wrong turn you're screwed. It's almost like you can see "checkmate in three" looming up ahead.
Redwudz,
Thanks for that tip. I'll look into this automatic recovery setting.When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form. -
If you boot into Safe Mode and run the computer for a while and get no blue screens, that would indicate that something that loads on normal boot (usually a driver conflict) is causing it. If you BSOD even in Safe Mode, its almost guaranteed that a piece of hardware is failing. Try to remember when this first happened; had you recently installed a new software, changed some hardware, etc.? It wouldn't hurt to run Malwarebytes and Combofix just to make sure you didn't pick up a virus.
Instead of guessing, why don't you read the dumps? They might actually tell you what failed just prior to the crash. What operating system are you running? What was the last thing you installed, hardware or software, before the problem started? Have you run a memory check?
I have in fact seen several (10-15 in the last 6 months) WD Caviar Blues go bad only weeks after they were purchased... all of them started causing bsods and eventually windows refused to start at all.
I've been out of town, and still won't have a chance to look much further into this until some time after the holiday. But I do have BlueScreenView now, and fired it up briefly to do a quick check of two memory dumps that I saved. What it is showing is
DRIVER_IRQl_NOT_LESS_OR_EQUAL
with these two items highlighted
ntkrnlpa.exe
scsiport.sys
The OS is XP Pro SP3, which is pretty much up to date on hotfixes. (I have not installed a couple items like NetFramework 4.)
I will run a memory check later when I get a chance, but I would bet you that there is nothing wrong with the memory or the HDD: the failures are too infrequent (and possibly random) for those to be implicated, IMO.
No new hardware has been installed recently. With one of the two incidents for which I saved the memory dump, the last change very shortly before the BSOD was a regular update to the NoScript add-on in FireFox. (And that may be another coincidence or red herring, as well.)When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form. -
Memory errors can be very infrequent. I'd run a memory test overnight, at least. But the error occurring in scsiport.sys implies a drive related error. Maybe a bad driver, cable, controller, or drive electronics.
It isn't SSDs themselves it is the Sandforce controller and it's firmware. I have 4 Intel SSds in use, Knock wood, No Blue screens or problems excluding the Virus my brother caught.
Supposedly the latest firmware has fixed most of those issues. How could they release a drive that has problems in something as popular as Dell alptops?
Agreed
I just did a HP rackmount server today amd one of the three Hard drives is bad. Brand new server grade drive and no good.
New does not always equal good.If I'd known I was going to live this long, I'd have taken better care of myself. -
Bluescreenview ... a handy utility from nirsoft ... thou pay more attention to the list of files in the upper pane which request access via
ntkrnlpa.exe
scsiport.sys
I'd look more closely at what files are linked to scsiport.sys ... it can also relate to a poor quality data cable connected to a drive and or a power supply which isnt coping. -
Well, it happened again this morning -- with only a FreeCell game running again. (I use that to help clear out the mental cobwebs, when I first power up in the morning.) But it probably has nothing to do with FreeCell . . . . At least it has not happened while I was running some long process overnight, or during various 2.5hr. video rendering jobs, or with my routine multi-tasking of 5 or 6 programs. The multi-tasking would be like FireFox + standard business app.s running during the day: when I'm doing video stuff -- other than say playback in VLC -- that gets sole use of the cpu. My point is that there have been numerous, better opportunities for this BSOD to happen, when it did not.
The last time was a month ago. In this pattern, I could live with this problem occurring once a month . . . though I would like to figure out the cause at some point. I now have a current version of Memtest86, and will run that soon. It probably won't be the memory, though.
I've got pages of Google hits to sift through, when I get the chance, but at first glance I'm leaning towards this post by "Proteus."
http://forums.storagereview.com/index.php/topic/4416-scsiportsys-bsod-in-xp/
Thanks to the system setting change redwudz suggested, I now have the complete BSOD:
DRIVER_IRQL_NOT_LESS_OR_EQUAL
STOP: 0x000000D1 (0x000000014, 0x00000006, 0x00000000, 0xB7ECF7B8)
Scsiport.Sys - Address B7ECF7B8 base at B7ECE000, Datestamp 4802539d
Assuming this even does relate to Scsiport.Sys, how do you backtrace what may be using that driver ? I need to become more familiar with the use of Bluescreenview . . . .When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form. -
When I get a blue screen it usually means a cooling problem. Usually a thorough cleaning of CPU and GPU fans gets it back. I usually re-seat the RAM during the cleaning.
http://www.kiva.org/about -
That's what Proteus was apparently saying in the thread I cited.
I have a MS KB that I just bookmarked that mentions a Windows defect, in some similar cases. And another message suggested that if it was an occasional driver timing issue (which might tie in with the BSOD happening shortly after boot-up, before there has been much time for heat to build up), this should be reflected in the Event Logs. Nothing like that however, although I do see one remaining piece of a bluetooth app. that was uninstalled a long time ago. That keeps turning up in the logs, but I don't see it having any relevance here. It does not want to go gracefully though, so I may have to go into Safe Mode to zap those Registry keys.
If I read through enough of these tech forum threads, I will probably stumble across the answer.When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form.
avisynth error: 64-bit windows not detected
By adom in forum EditingReplies: 10Last Post: 20th Mar 2011, 06:35 -
JVC DV Camera Not Detected in Windows XP
By Mark97213 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 2nd Jun 2010, 11:22 -
A problem has been detected and windows has been shut down....
By gooberguy in forum ComputerReplies: 6Last Post: 10th Nov 2009, 16:11 -
problem in megui causing SHUTTING DOWN my computer !
By LOST World in forum DVD RippingReplies: 5Last Post: 15th Feb 2008, 04:45 -
Windows 98SE PC is shutting down before booting to desktop
By edong in forum ComputerReplies: 4Last Post: 27th May 2007, 17:27
![Computer details: [This list is SELDOM up-to-date !]
Shuttle SX48P2, Q9550, 4Gb.
ATI Radeon 45__ (?)
Win-7 Ent. x86
WD Black 500Gb. + 1Tb.
Shuttle SP35P2 Pro,
Intel Xeon 3230, 8Gb.
ATI FireGL V3400
Win-7 Ultimate x64
Shuttle SH67H3 (i5)
w/ 16 GB. RAM &
Win-10 Pro
SSD + HDD
LG Blu-Ray burner
[acquired used as an already-HTPC,
though not yet assigned to that task]
Shuttle SH67H3 (i7)
w/ similar config to the one above
and others
[also (reluctantly) perform some "IT-by-default"
services for an office, with other computers
there . . . ]
Various older model Lenovo laptops, like T-40
series, T-60
IPAD Pro (Gen. 2)
Video Gear includes:
Oppo 95-BR
Pioneer 520, 640, 460
Toshiba 32HL67
Panasonic G-25 plasma
Pan V-series 58 plasma.
TBC-1000 & other assorted gizmos
Panasonic 4820-SVHS
& various other VCRs
Various Betamax gear
Var. video streaming boxes Comp](/images/buttons/computer.gif)
