Hi there,
I’m desperately looking for a solution to a problem I’m having burning DVDs in Encore CS5.
Essentially I’m getting poor quality, washed out and slightly grainy footage on my DVD burns, and yet the videos I am burning are perfect quality when viewed from my HDD.
My workflow, simplified:
• Taken the original footage and imported into After Effects to create any
effects etc.
• Exported from After Effects and imported into Premiere to create final
edits,
• Exported from Premiere and imported into Encore to arrange and
author DVD.
Throughout the process my settings have been as follows:
• MPEG2 PAL 25fps, 720*576px, VBR (Min2, Avg7, Max8), Lower Field First, PCM Audio (as separate file)
… and right up to (and including) the point of viewing the footage in Encore’s ‘monitor’, it looks sharp, crisp and well coloured. It’s only once it’s burned onto the DVD that it looks pretty awful.
Things I’ve tried (to no avail) are:
• Using Dynamic Link instead of exporting / importing between programs
• Trying CBR and VBR with different settings.
• Leaving the footage un-transcoded as they are already MPEG2 with
PCM audio.
• Transcoding with the ‘Automatic’ setting.
• Created an Encore DVD project with just one video (the shortest video
of the crop), and set the transcoding to automatic (to see if space
constraints caused transcoding lower the quality).
• Same as above but not transcoding the video.
• Using different media to burn onto.
• Creating an ISO image of the DVD and burning on another computer.
I’m at a loss with what to try next, as the client’s deadline is creeping up and this is the last barrier to what is otherwise a smooth ride finishing this project.
If anyone has any ideas, comments, or even better - fixes - any help would be much appreciated, as I just get the feeling there is something right under my nose which I’m missing!
Many thanks indeed.
What program are you using to burn? Is there any chance that your burning program may actually be re-encoding your video prior to burning? Nero has been somewhat infamous for doing that if you're not careful. How long do your burns take? (This can help us to figure out if your burning software might actually be re-encoding your videos.)
Others will have to help you with the software you are using as I have no experience with those programs. -
your work-flow looks pretty OK, it is weird that you do not get desired quality output on DVD.My workflow, simplified:
effects etc.
edits,
author DVD.
alternatively you can try
original footage --> After Effects --> DV-AVI --> Premiere --> MPEG2 PAL 25fps, 720*576px + AUDIO (pcm or mp2) (one file) --> Encore
Author DVD on HDD and burn it on branded DVD using imgburn, if it does not contain encryption. -
Is your monitor calibrated correctly ? and/or is your DVD/TV setup calibrated correctly ?washed out and slightly grainy footage on my DVD burns
What happens when you view the burned DVD on the PC through DVD playback software ?
I'm thinking your PC monitor is calibrated incorrectly, so when you make adjustments based on that, it's actually something else. When black level isn't adjusted properly and elevated, noise that is not normally visible becomes visible
DVD quality from Encore CS5.1
By surffx in forum Authoring (DVD)Replies: 6Last Post: 21st Nov 2011, 04:51 -
encore dvd adobe cs5
By donnaglait in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2011, 06:30 -
Finished DVD in Premiere CS5 - transcode in Encore?
By Mylo in forum Authoring (DVD)Replies: 4Last Post: 23rd Feb 2011, 07:55 -
Menu creation in Encore CS5
By mobie29 in forum Authoring (Blu-ray)Replies: 0Last Post: 16th Aug 2010, 13:17 -
Encore CS5 Loss in Rendered DVD chroma/saturation
By CKyle in forum Authoring (DVD)Replies: 0Last Post: 17th Jun 2010, 17:00
