I had been successfuly playing 720p MKV files on VLC for a few days. My computer was clearly powerful enough to do so. All of a sudden, the picture is horribly shaky/wavy with constant pixelation whenever an MKV file is played. Things are normal with AVI. I didn't change any settings or anything. Does anyone have any idea what could be going on?
PC overheating? CPU maxed out ? (check Task Manager)
DO the same files that played good earlier still play OK now? -
CPU usage does not go above 25%. Files that previously played perfectly are now wavy/shaky/pixelated to the point you can't recognize what's on the screen. Out of about 10 mkv files, there is one that still works, I don't know why. After my first post, I remembered that, in attempting to maximize picture quality, I messed around with "deinterlace", "deinterlace mode", "post-processing" and probably a few other things in the video settings in "preferences". However, I uninstalled and reinstalled VLC, and the problem persists. I find it really strange, since I had watched all these videos from beginning to end and there was no problem. I can't figure out if the problem is with VLC or my computer; although I can't imagine what would have happened to my computer between Saturday and today to cause this change. The only thing I did was watch an abundance of mkv videos.
Yeah, you're right, and I'm a moron. I forgot I had been messing around in the Input and Codecs settings. I reset it and it's fine now. Funny uninstalling/reinstalling didn't help; but anyway, thanks for the help.
Not a problem, glad you sorted it.
Often, when programs are uninstalled, these kinds of preferences, usually stored in the
HKEY_CURRENT_USER part of the registry are kept, so you can have your prefences back if you reinstall.
Some programs ask if you want to keep them or not.
VLC not playing mkv(720p, h264) files smoothly?
By swalih in forum Newbie / General discussionsReplies: 15Last Post: 9th Mar 2012, 20:31 -
VLC 1.1.10 not playing MKV
By pooksahib in forum Software PlayingReplies: 2Last Post: 1st Jul 2011, 04:49 -
VLC not playing MKV
By stringcheesy in forum Software PlayingReplies: 1Last Post: 19th Mar 2011, 04:29 -
VLC player not playing MKV file
By GLE3 in forum Software PlayingReplies: 3Last Post: 15th Feb 2009, 16:39 -
Best Aspect Ratio playing .mkv video via VLC/Quicktime for viewing on HDTV
By iMacMan in forum MacReplies: 4Last Post: 19th Feb 2008, 02:04
