Yeah, we all have programs to keep track of movies we have. What I'm looking for is a program to track the movies I've seen in a rotating list. I watch a movie at the top of the list. After I watch it I'll mark it watched and it drops to the bottom of the list. This way I don't keep watching the same movies over and over.
Currently I have a box with my movies in sleeves. After I watch the first movie in the box I put it to the back of the box. I'd rather have a program to do this.
I had a program where I put a number in the "title sort" and changed the number after I watched the movie. Basically it worked but it was kind of a hastle.
Don't give in to DVD2ONE, that leads to the dark side.
Have you considered a simple spreadsheet? Use a column for the date you watch a film, then you can sort by date watched. If you already have a list of the films you own export them to a text file as the staritng point.
They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
can't you do this in access, vb or delphi ?
(a simple CheckListBox control is all you need. delphi has it and i'm sure vb does too)
you could create a listing in .txt format on your hdd, and then load that into the checklistbox control at startup
create a TiniFile in the apps folder and write the last inc counter there
when you load the rolling list box app, you get the last count and increment it and then save it
here's a vague howto to get you started
1. add a tinifile to your uses clause (reading/writing ini, or use your own method)
2. throw a checklistbox on your form
3. load the checklistbox with the the movie listing, ie movielist.txt
4. when you finish watching a movie, put a check next to the name (make sure it is not set to multi-select)
5. save it. create a button event [Save] or something, or whatever works.
fine-tune the app, the usual that goes into a programming project.
the listing would have to include a sortable indentifier for each item and each time you read/save, you refresh it to the given order so that the list sort of bumps down by one, like. i'm not very good at explaining things, but i hope are getting some ideas from this. or maybe someone can create something simple. -
I'm setting up something in Excel. Should do the trick. I just figured there may have been a program that already did this.
ThanksDon't give in to DVD2ONE, that leads to the dark side. -
am i the only one that finds this to be rather odd? don't you know if you've seen a movie or not? is your memory that bad?
If you read my original post again you will see it says a “rotating” list. Track the movies in rotation. Once I watch a movie from my collection it would go to the bottom of the list. That way that movie will not get watched again till I have gone completely through the list of movies. This way the same bunch of movies will not get watched too often. I’m sure there are some movies you wish you hadn’t watched that often. Even though you love them you just can’t sit through another viewing. A good example for me would be “Back to the Future”. I hadn’t watched it in over ten years. I just recently watched it again and enjoyed it. Hope this makes it clearer.
Program to add an audio track to a mkv file?
By supercain in forum Video ConversionReplies: 4Last Post: 19th Dec 2011, 11:56 -
I keep thinking this can't be right - 7gb for 1080p? Harry Potter movies
By AndyD in forum Blu-ray RippingReplies: 7Last Post: 17th Oct 2010, 09:45 -
Thinking of ditching AppleTV and using PS3 for movies/music/photos
By bobogs in forum Media Center PC / MediaCentersReplies: 7Last Post: 14th Nov 2009, 23:21 -
Best way to replace an Audio Track on x264 Video Movies...
By erosoft in forum Blu-ray RippingReplies: 2Last Post: 4th Dec 2008, 10:25 -
Freeware program that edits movies
By LITEONDVD in forum EditingReplies: 3Last Post: 21st Jul 2007, 11:25
