hellllllllllpppppppp i rip music videos and then i cut them up (cuz i record a hour of videos and then wanna cut it up), and i am using tmpgenc, and it works fine it dont lock up or anything but they are out of sync when i cut with it...really bad by like 2 seconds.....help!
<font size=-1>[ This Message was edited by: KillerSoundz on 2001-07-26 11:43:53 ]</font>
to cut in v-dub:
using edit-> set selection start / set selection end select the part you don`t want [it`ll highlight it in blue]. then use edit-> delete selected frames. do this till ya get whatcha want...
btw - to get closer to the actual frames you wann cut to and from use shift and left or right cursors to select keyframe by keyframe
also, remember that the selection you make for when u`r cutting is INCLUSIVE - so it`ll cut the frame u selected when chosing which section you wanted cutting.
hope this helps dood
bap -
thanks for the fast reply dood, i am gonna try that know i will tell reply when i am done and tell u my end result thanks again dood
thanks it helped alot it was also outta sync the same way it was the other ones i did with tmpgenc, but i found out it was my rip =P cuz i did this like 100 times with tmpgenc before and it worked fine it was just this rip.....dropped some frames and crap cuz when i ripped it my puter been on for about a week without a restart thanks
Loss of Audio Sync after cutting (Avidemux)
By Maverick-X in forum EditingReplies: 4Last Post: 14th Oct 2011, 15:12 -
Help reset my expectations - how big the rip will be, time it takes to..
By AndyD in forum Blu-ray RippingReplies: 3Last Post: 26th Nov 2009, 13:10 -
cutting down big recording
By Jackmac191 in forum EditingReplies: 7Last Post: 15th Feb 2009, 08:14 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
cutting a large WMV - audo/video sync is off
By djbryson in forum EditingReplies: 4Last Post: 20th Aug 2007, 13:38
