I have no previous experience with MKV files. I have always converted them to xvid. But with a new TV I tried to embed srt subtitles into an MKV file using MKVtoolnix.
However whenever I go near the file I get "Windows Explorer has stopped working" and then the PC crashes. I had to erase the folder.
I have done it three times all with the same result. The third time I outputted it straight to a USB stick but my TV would not recognise it although it had no problem with the original.
The original MKV file already has English subtitles embedded. I wanted to add Polish.
I am using windows 7.
I presume it is a codec conflict but I would not know.
Any idea?
I don't know if this is your problem in this case, but it could be. Windows 7 has a known bug regarding some (NOT all) MKV files. Basically Windows just freaks out on certain MKV files. In some cases the files cannot be deleted. I have seen this issue personally. There's also a known issue with Windows Explorer dying and locking up the PC, although that is not necessarily related to the MKV issue.
Here's the bad news. Nobody really knows why these are happening, what is causing them, or how to fix them. There are a few guesses on the Windows Explorer issue, but they involved dubious registry hacks to try to fix. You're on your own to research them and do them if you wish. I have no confidence in them and have not done them. Nobody has any clue what is causing the weird MKV problems in Windows 7 and I haven't seen any attempts at a fix for those. -
Does Win7 still allow you to access the DOS/Command Prompt? If so, you can open that, change to the directory and delete the file from there.
For example:
I had to do that, once, on my Vista system, to get rid of an MKV with a font that was somehow causing Explorer to crash.Code:cd temp del file.mkv
If cameras add ten pounds, why would people want to eat them? -
are they in a font your computer doesn't have? or in a different format than the english ones? have you tried getting a different version of the subs?
aedipuss, you are quite right. If I change the "system locale" on the computer to Polish I get a fully working mkv and no crashes.
I have however discovered that an srt converted to idx first produces a file which does not crash window explorer even with "system locale" kept in English
How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACT
By lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 14:04 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 02:45 -
embed srt into mkv
By Soixante in forum Video ConversionReplies: 3Last Post: 16th Oct 2010, 04:00 -
embed test
By racer-x in forum TestReplies: 2Last Post: 14th Dec 2007, 18:00
