Apologies in advance if this is a dumb question. I just got a MICCA-HD media player with usb and SD inputs; it plays everything I plug into it including a hard drive. But there are some instances where I'd like to be able to burn my media files to a DVD as data (as I also have a dvd player in another room that plays divx from discs). But the MICCA media player won't read off a disc in my portable dvd drive, even though it will read just fine from an actual hard drive. I'm assuming it's something to do with a hard drive being bootable and the dvd isn't, so is there anything I can add to my discs in future to make them readable to a media player such as this? In other words, can I make the external dvd drive appear as if it were an external hard drive so that the media player will read off it? Thanks for any advice.
You can't add anything to the dvd media to get it to work. You probably need a custom firmware to get it to work, check in http://forum.miccastore.com/index.php/board,3.0.html?PHPSESSID=0a2a4847f4c9a94adbdf1cdd3e68c0d3
The media player doesn't support the ISO/UDF/Joliet file system used on optical discs.
Thanks, I've since realized that I would need to format the discs as FAT32 or NTFS, which isn't feasible for a dvdr.
WD External hard drive no longer works with my LG DVD Player
By KarlKarlson in forum DVD & Blu-ray PlayersReplies: 0Last Post: 28th Feb 2010, 13:16 -
DVD player with external Hard drive
By dbnite-wp in forum DVD & Blu-ray PlayersReplies: 14Last Post: 23rd Sep 2009, 02:46 -
Question about using external hard drive with USB DVD player
By jimdagys in forum ComputerReplies: 2Last Post: 29th Jul 2009, 19:49 -
External Hard Drive to DVD Player through TV
By illpeeonu in forum DVD & Blu-ray PlayersReplies: 7Last Post: 5th Feb 2009, 13:02 -
Is It Possible to Make Multiple Drive Images on One External Hard Drive
By drstew in forum ComputerReplies: 17Last Post: 24th Nov 2007, 09:47
