    Dec 2011
    Minnesota
    I am new to this site and a novice at making movies. I spent considerable time editing my footage from several vacations (each one a separate project) in Pinnacle Studio 11. When it comes to making the actual movie and burning to DVD, it appears that each project must be made into a movie separately. Does anyone know of a way to merge the projects into one movie/DVD?
    I have used the software before but this is the first time I have encountered this issue. I don't want to re-edit all my footage into one project.
    Thanks for any help!
  2. Member zoobie's Avatar
    Feb 2005
    Florida
    I don't have Pinnacle but most editors have the option to import another project into the timeline. However, the settings must be exactly the same...identical even or it will re-encode.
    Mar 2008
    Presumably all your existing projects exist in one format or another. What format are they in?
    Do you only have single DVD's of them (video_ts folder) or did you keep some other format?
