Hi,
Im currently using the program to put together 4 or 5 videos and have them all playable on a single Blu Ray disc.
The program works a treat in general, I thought I may struggle with it but has been pretty simple over all, and i can create the BDMV folder no problem at all.
However when I play the output BDMV folder in VLC it doesn't play the files in the correct order, I thought was a mistake on my part at first so re authored the files once again making sure i added them and had them in the correct order but yet again the result was that the disc did not play in the correct order, I have attempted to look thru the setting for something that may help me but I haven't found anything. I decided to have a look in the Blu Rays "STREAM" folder, and I noticed that the .m2ts files in the stream folder are in the correct order, when I play file 00000.m2ts it is indeed the first file i wanted to play, 00001 - 00006m2ts files also in the folder are in the correct order. So it seems to be only when I play the folder together that the order is mixed up.
I tried to play the folder in MPC also but that was not successful as i got the message "unable to render file"
So my question is really, anybody know of a setting I may have missed that may help me, or a reason that this may have happened?
Look forward to reading some great advise from members here as usualIf any info on the files im using or any other information is needed please let me know and ill do my best to provide.
Thanks in advance
Results 1 to 1 of 1
Dvd to Blu-ray multiAVCHD
By Marco33 in forum Authoring (Blu-ray)Replies: 5Last Post: 26th Jan 2012, 11:34 -
My Multiavchd/Blu ray project came out 85% but how do I get it better?
By jbitakis in forum Authoring (Blu-ray)Replies: 0Last Post: 8th Jan 2012, 00:34 -
Multiavchd..Need Help..MKV-BLU RAY-- Freezing on Blu Ray Menu!!
By Thuglas in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Sep 2010, 22:58 -
Multiple blu ray titles-No menu with AVCHDcoder or MultiAVCHD?
By thegeeman in forum Authoring (Blu-ray)Replies: 6Last Post: 22nd Sep 2009, 08:22 -
Playing Ripped Blu Ray on PS3 - Audio Problem
By toranaBob in forum Blu-ray RippingReplies: 0Last Post: 24th Feb 2009, 18:26
