I have a logitech z506 sound system and an Hitachi dv bp100uk Blu Ray player and a Luxor 42" HD TV
I thought i had set it up correctly, alas no
The surround sound works fine as i tested it through the BluRay
I have the TV set to HDMI1 and the Bray to HDMI2, TV works fine
Switch to HDMI2 and i get no picture but great sound, now if i switch back to HDMI1 the sound from HDMI2 is also there, so i probably done something wrong here. (edit as it does it withh both HDMI's)
Although when i switch to BLuray the Hitachi Logo is displayed on the screen, but then black only
I wondered if anyone could help please
EXT2 gets a TV picture as does ext2S (although B&W), bit unclear as to why as i couldnt get a picture through these before
is the blu-ray set to export video over hdmi? it most likely also has component and composite outputs, try one of those into the tv and see if you get a picture. then use the setup menu to choose hdmi out.
what do you mean the tv is set to hdmi1? the tv itself doesn't need an input, do you mean cable tv input or something?--
t.v. connection problem
By brenda1906 in forum Newbie / General discussionsReplies: 10Last Post: 27th Mar 2010, 07:18 -
sound connection
By alintatoc in forum ComputerReplies: 9Last Post: 8th Oct 2009, 00:32 -
connection question
By MAIOF in forum Newbie / General discussionsReplies: 1Last Post: 22nd Dec 2008, 12:23 -
PC to TV Connection help
By mohit in forum Media Center PC / MediaCentersReplies: 5Last Post: 22nd Sep 2008, 15:15 -
By mohit in forum Video Streaming DownloadingReplies: 1Last Post: 21st Sep 2008, 10:03
