So is there anything that works with HDMI input and by passes the HDCP? Or is the Hauppauge 1212 HD-PVR High Definition Personal Video Recorder using component still the only way to go? What about using a HDMI to component adapter so I can run long HDMI cable to my pc? Or will the HDCP still get picked up? Thanks
Results 1 to 15 of 15
You can run a long component cable to an HD PVR. How long do you need to go?
http://www.kiva.org/about -
An AverTV HD DVR has the ability to handle HDCP encrypted HDMI. But you need to use an old driver and a trick to get it to record that.
https://forum.videohelp.com/threads/335793-AverTV-HD-DVR-drivers?p=2085099&viewfull=1#post2085099
You need a pretty powerful computer to compress HD video in realtime. -
There are HDMI to component adapters (the HDFury series is one example) but they are not sold in the US. Understandably, retailers don't want to be taken to court for selling them. Building a device that strips HDCP is a violation of the HDMI and HDCP licenses, so they would be selling an unlicensed product. It also probably violates the DMCA.
HDCP doesn't apply to analog connection, and the HD-PVR apparently ignores analog copy protection flags which may be present in the component video output of satellite receivers and cable boxes. -
Actually, they are:
http://www.amazon.com/ViewHD-Component-Converter-Support-Surround/dp/B004F9XVBC/
http://www.amazon.com/SPDIF-Component-Ypbpr-Converter-v1-3b/dp/B002SFT3ZI/
I've been thinking try one of those. I'll also need an HDMI splitter:
http://www.amazon.com/ViewHD-Powered-Splitter-Certified-Outputs/dp/B002673EW6/
so I can continue to send HDMI to the TV.Last edited by jagabo; 4th Dec 2011 at 10:35.
Yeah. One shouldn't wait too long...
Actually, I think it's legal to sell an HDMI+HDCP to component+CGMS-A device. What's not legal is a HDMI+HDCP to HDMI (clear) device. -
In the end, it doesn't matter whether it's legal or illegal. What matters is who has the deepest pockets and can afford a long protracted court battle. There's no doubt Intel is the winner here. (For those who don't know, HDCP is Intel's baby.)
Ok thanks... I would like to have 5.1.... Will the Hauppauge Colossus work with HDCP & HDMI input without using a HMDI to component converter? Like a software update or something? Is there a bid difference in sound from stereo to 5.1? I will be playing these files on a HD media player or burning to Blu-Ray...
The Hauppauge Colossus won't record HDCP protected HDMI, but will record from a component connection and provides a component video pass-through like the Hauppauge HD PVR. It is an internal card, which some people might prefer to a USB device. Choosing 5.1 audio vs stereo is a personal decision, but if you don't have or (plan to get) a home theater system or surround-sound speakers for the PC, 5.1 audio doesn't matter much.
How do satellite & cable company's play HD movies
By neworldman in forum Off topicReplies: 6Last Post: 5th Dec 2010, 13:18 -
Sudden resolution change when recording HDTV
By Strawson in forum EditingReplies: 9Last Post: 20th Aug 2010, 14:49 -
HDTV possible on an old black & white TV???
By yoda313 in forum DVB / IPTVReplies: 10Last Post: 31st Jul 2009, 05:31 -
HDTV VCR recording, VHS TAPE?
By jb66 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Oct 2008, 17:45 -
Recording cable HDTV via firewire
By hipser in forum DVB / IPTVReplies: 3Last Post: 18th Apr 2008, 17:58
