Well this one had me spinning: Picture transferred from DVD fine. But I tried to redo it several times not noticing that the audio was Pulse Code Modulation. The transfer to an avi file has no sound. Is it simply a matter of using the right player?
I use VLC which is supposed to do it all.
Any help on this audio problem?
Results 1 to 9 of 9
shouldn't be avi from a dvd. try again just get the original mpeg-2 from the vobs.
can't say i ever came across a video in an avi container with pcm, maybe not an acceptable audio format.
ok crap you win. i just tried an avi from a dslr and it had pcm and mjpeg, if that plays ok i guess anything can.
It depends on the edition that DVDFab has come out. MKV is now offered in the newer one. But if PCM is raw audio can the prog even see it? I even swapped around the 5:1 dts audio in place of stereo-- still no go.
I will run the file through GSpot as you suggest.
Will follow up tomorrow. Since the sound on this is important, I'd rather not have to go through trying to tease it out which I'm no good at anyway. -
AVI container encoded with H.264/AVC video and PCM sound
By LoLaha in forum Video ConversionReplies: 6Last Post: 20th Mar 2012, 22:14 -
A DVD to AVI with no sound in DVDFab
By loninappleton in forum DVD RippingReplies: 3Last Post: 30th Jul 2010, 14:08 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27 -
Playing PCM audio within AVI file
By acid_burn in forum Newbie / General discussionsReplies: 1Last Post: 25th Dec 2007, 03:27 -
Replace audio stream in a DV AVI file
By dzoge in forum EditingReplies: 3Last Post: 6th Jun 2007, 18:57
