I need to buy a new dvd player anyway and I was wondering if there is one that I can make region free and record dvd to vhs using only the remote control. I don't have a cd burner. Thank you
Results 1 to 12 of 12
Hi,
I don't think that what you want is possible. To record a DVD to VHS you ALWAYS need the DVD-player unit. Not just the remote !!! (just a joke..)
You are probably looking for a DVD-player which is, or can be made, region free AND macrovision free. The Player that i own, which is an Amoisonic 8605F is both region and macrovision free.
Greetz,
pSyChO dAdThe difference between genius and insanity is only measured by success ! -
I read the review here on your player and it was just average. Is it a good player that will last awhile? I have over 500 dvd's, so I use my player almost every night. I have a toshiba sd2109. It worked for 3 years, but now won't play duel layer dvds. Since I have to replace anyway, I thought it would be nice to get a player that I can do more with. Thank you, your player has a good price on it too.
If you live in the uk Asda do a player which is remote hackable for region free, including RCE, and macrovision, plays just about everything including MP3's and is less than 90 quid.
Pacific 750
Craig -
Hi,
Well, i'm very happy with the 8506. It has Dual scart, Region free/selectable, macrovision free, dual Karaoke ports, Build in DD/DTS decoder with analoge output. Digital Coaxial and optical output. I think is i very good player, that does a lot.
Concerning durability, i have no clue. I have mine for about 2 years now and play movies almost dayly. I Own about 150 DVD's and 250 VCD's so movies is a big hobby of mine too.
Greetz,
Psycho dad- Where can I buy this? The link from this site goes to some site that is in Chinese and I can't find it on Amazon. Is there a B&M store that carries it? Thanks for all the help.
Craig-I live in the USA, thanks anyway. -
In the UK from Tesco, Dansai 852, plays everything and hacks from remote
Mickle -
Hi,
The One shop i bought mine from is in Rotterdam. I don't know if they ship overseas.... So Sorry.
Greetz,
Thanks for trying to help. I should have said that I live in the US on the first post. Sorry, my fault I am new at this. Thanks again.
Hi
I own the YELO 800 DVD player. So far it has played every media i have thrown at it even cheap 10 pence CDR's. It also has the function to access a hidden menu via the remote control enableing you to turn off Macrovision. The DVD player itself is a multiregion but an also be set to the desired region in the hidden menu. This player is top class and i would reccomend it to anyone. I payed £149 for mine off of amazon.co.uk - a complete bargain for the features it posesses.
Check out some of it's features here:
http://www.vcdhelp.com/dvdplayers.php?DVDname=&DVDselect=Yelo&Submit=Search&Search=Search
The Jackal. -
Thank you. The apex 3201 looks like it got good reviews and I found it on several sites to order. I also found the remote hack for it on here. I am ordering it. Thanks again.
Victor DVD player hacks, no where to be found?!?!!?
By hiko in forum DVD & Blu-ray PlayersReplies: 3Last Post: 23rd Dec 2010, 23:55 -
What to buy today for Macrovision removal (VHS tapes).
By cowmix in forum Capturing and VCRReplies: 3Last Post: 10th Mar 2010, 17:18 -
DVD Record-Player firmware/hacks
By wguru in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2008, 13:53 -
Dodge/Chrysler DVD Player - any hacks for region codes?
By paulfnyc in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Nov 2007, 10:35 -
beware of DVD player hacks scams
By lordsmurf in forum DVD & Blu-ray PlayersReplies: 9Last Post: 20th May 2007, 02:33
