I'm new here so if this has already been asked and solved please just put the link here. I haven't been able to find what I was looking for through a quick search of the site.
I do freelance videography with the Canon T2i and I need to figure a way around the 12 minute record time limit. Is there a way to record straight to my Macbook Pro (or hard drive)? I have Final Cut Pro 7, Adobe Premiere Pro, and the entire Adobe Suite CS5 (including OnLocation). Will any of these work?
Or can I (someway) buy a DVD recorder and record straight to the DVD (or if it has a Hard Drive built in it)?
I'm looking for options here. It's been a hassle trying to record videos and having to piece together 12 minute clips.
	buy a real camcorder? --
	No, because:
 1) Macbook would need a pci-e slot for external capture card (or some other recording device)
 2) HDMI output isn't clean on the T2i - there are graphic overlays, and resolution is reduced
 There is a "magic lantern" firmware hack, but I don't think they've solved problem #2
	An HDV camcorder streams HD MPeg2 over Firewire live to a Mac or Windows machine. Problem solved.
 HDMI out of an AVCHD camcorder can go about 20 ft to a Decklink box to SDI to a Mac tower with SDI card and captured MJPEG or uncompressed to a RAID.
 HDMI out of an AVCHD camcorder can go about 20 ft to a Windows PC with BM Intensity card captured to MJPEG.
 A Pro camcorder outputs SDI directly to a Mac tower or PC with SD card.
 For a Canon T2i, you can export SD analog composite to a DVD recorder or capture composite with an Elgato USB stick to your MacBook.Last edited by edDV; 4th Dec 2011 at 00:13. Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
  What can I use to record Xbox footage with this setupBy giggsidan in forum Capturing and VCRReplies: 80Last Post: 25th May 2012, 00:16
  Very 1st time exposed to straight AVCHD footage: HELP !!By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 5Last Post: 31st Jul 2011, 18:37
  Capture video straight to DVD (for MAC)By eutapio in forum MacReplies: 11Last Post: 29th Apr 2011, 16:19
  Question: Experiences with using DSLR to record HD VideoBy CogoSWSDS in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 3rd Oct 2010, 19:58
  Record straight to DivX/Xvid ?By joecass in forum Newbie / General discussionsReplies: 2Last Post: 17th Sep 2009, 12:58
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
