I am using Vegas to author a movie to Blu-Ray. The resulting file is a 26.8 GB .iso file. Is there a program that will in turn read this ISO off the hard drive and shrink it just enough to fit on a BD-25?
Mount the ISO in a virtual drive. I recommend Slysoft's free program VirtualClone Drive. Use BD Rebuilder (also free) to reduce the size to fit your 25gb disk target.
BD Rebuilder requires three auxillary programs, but you can find the downloads for all three at the BD Rebuilder site at doom9. Here is the page: http://forum.doom9.org/showthread.php?t=143716
I recommend using ImgBurn to do the actual burn to a disk. www.imgburn.com
If you need a guide for setting up BD Rebuilder, this one is a bit out of date, but should still be sufficient: http://club.myce.com/f142/bd-rebuilder-guide-313227/ -
Thanks for the support. I'll read through the documentation and give them a shot. Feels good to be editing again.
How to shrink a blu-ray iso file & keep menus
By neworldman in forum Blu-ray RippingReplies: 7Last Post: 5th Jan 2014, 21:35 -
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
DVD shrink and ISO playback with WDTV
By neworldman in forum DVD RippingReplies: 3Last Post: 14th Apr 2010, 14:40 -
DVD Shrink .ISO/.MDS issues...
By AGenius in forum DVD RippingReplies: 6Last Post: 19th Mar 2008, 13:53 -
DVD Shrink to VOB,IFO, BUP and then IMGtool to ISO, bigger than 7GB
By opieandy in forum DVD RippingReplies: 3Last Post: 28th Sep 2007, 16:04
