  1. Hi folks,
    I have an AVI file that it seems it Skips Frames during the playback.
    I have tried playing it with VLC and even on my stand-alone home media player (Netgear, it is like WD Media Player) ... and the AVI file seems that it skips frames. The file is not packed bitstream ... so it is not that problem.
    Below is the MediaInfo data ...
    General
    Complete name : F:\Test File Skips Frames.avi
    Format : AVI
    File size : 168 MiB
    Duration : 26mn 3s
    Overall bit rate : 900 Kbps
    Writing application : MEncoder Sherpya-SVN-r25962-4.2.3
    Writing library : MPlayer
    Video
    Format : MPEG-4 Visual
    Format profile : Simple@L3
    Format settings, BVOP : No
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Codec ID : XVID
    Codec ID/Hint : XviD
    Duration : 26mn 3s
    Bit rate : 767 Kbps
    Width : 320 pixels
    Height : 240 pixels
    Display aspect ratio : 4:3
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.400
    Stream size : 143 MiB (85%)
    Writing library : XviD 1.1.2 (UTC 2006-11-01)
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Mode : Joint stereo
    Mode extension : MS Stereo
    Codec ID : 55
    Codec ID/Hint : MP3
    Duration : 26mn 3s
    Bit rate mode : Variable
    Bit rate : 121 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Stream size : 22.5 MiB (13%)
    Alignment : Aligned on interleaves
    Interleave, duration : 26 ms (0.65 video frame)
    Interleave, preload duration : 542 ms
    Q1: Can someone tell me what is causing this porblem?
    Q2: Is there an easy Fix to this?
    Thanks,
    G!
    Mar 2008
    Open the file in Virtualdub and find a section that shows the problem (somewhere with some motion).
    Look at it one frame at a time (right arrow key) and see if you see frames that are duplicates of the previous frame
    and / or appear to jump further than it should.
    If you're unable to figure out what is wrong, cut out a small section with Virtualdub and post it here
    (somebody will take a look) You can post up to 30MB.
  3. Yes, you need to determine whether you have a playback problem or if the problem is the video itself.
  4. Hi davexnet & jagabo,
    Thanks for your replies.
    Assuming the problem is the Video itself ... is there an "Easy" fix to it? If so, what do I use to fix and How?
    Thanks again!
    G!
    Mar 2008
    Impossible to answer without looking at it (which is why I mentioned uploading a portion).
    There may be a "pattern" that can be solved with a good Avisynth script.
