Hello all - long time lurker/reader, first time poster. Trying to convert some .TS files to MPEG2 for authoring a custom DVD and got one file that's giving me a hard time with every encoder I try to run it through, despite it playing fine in MPC. Managed to Demux it with Project-X and found that it was the audio that's giving me problems - the AC3 stream has a 35ms bit of 2.0 audio before the 5.1 kicks in. Managed to separate the two streams with splitac3 but now of course I'm having syncing issues with my encodes - was hoping a mere 35 milliseconds wouldn't be an issue, but no such luck. Still relatively new to all this, how to I proceed at this point to resync the two streams? Do I need to trim 35ms off the start of the video stream before encoding the two? Which tool(s) would I use? Any sort of help would be greatly appreciated - I'm sure its probably an obvious fix but I'm at a loss at this point. Thanks!
you can add the delay (either when multiplexing the audio, or authoring the DVD)
or you could join 35ms of blank 5.1 audio
MKV stream extraction causing audio sync problems
By PlanetIndigo in forum Video ConversionReplies: 18Last Post: 29th May 2011, 22:07 -
ffmpegX flv causing problems with blip.tv player
By orionrush in forum ffmpegX general discussionReplies: 0Last Post: 17th Feb 2011, 17:55 -
Besweet causing problems?
By hardcorejason in forum Video ConversionReplies: 1Last Post: 27th Apr 2008, 13:59 -
is this pinnacle, dazzle or my new PC causing my frame dropping problems
By arthur1971 in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2007, 02:41 -
TMPGEnc problems with RMVB -> Mpeg2 conversion
By rebel316 in forum Video ConversionReplies: 2Last Post: 7th Aug 2007, 04:33
