I got all my media in .mkv format (in 720p or 1080p) and I want to resize it to a small screen on my Asus Transformer Tablet. I read that 720x480 is good enough.
Bascially I need to get the file small as a tablet doesnt need just a high resolution.
The problem is that when I use CyberLink MediaEspresso some of the audio does not work. So this software is not robust at all.
What is the best resize software that can do the job and work with any audio, not to mention video also.
I have Klite Mega Codec pack install on my PC.
If you want to do a LOT of work yourself and spend a lot of time on it, you can write AviSynth scripts and use VirtualDub or VirtualDubMod to encode, but it's not going to be quick or easy that way. Handbrake is a good choice for inexperienced users. Are you REALLY going to spend hours just figuring out how to use AviSynth and VirtualDubMod? There are guides available to using those programs so please don't tell me you're too stupid to find them now that I told you the names of the programs. It's a tablet - exactly how "mother of all resizing" does it REALLY need to be? Handbreak is pretty good and even if you do it yourself via AviSynth and VirtualDub you're looking at best at maybe geting 5-10% better results. I'm not sure you'd be able to tell any difference.
You should be smart enough to understand that any time you ask someone "What is the best ________ ?" that you're going to get a different answer depending on who you ask. There is no "best". Your "best" might mean "What is the best quality?" Another person's "best" might mean "What is the fastest?" and so on.
Statements like that are likely to make people not take you seriously around here. Many of us have a VERY different opinion about Klite.
Since you're new, I'm going to warn you - I'm already getting a bad feeling about your general attitude due to your 2nd post in this thread. I would advise you to choose your words very carefully for any further posts.
Resize & Crop MKV
By Kand in forum Video ConversionReplies: 2Last Post: 22nd Apr 2012, 13:50 -
[SOLVED] resize an mkv for a 16:9 tv
By rekotc in forum Newbie / General discussionsReplies: 28Last Post: 7th Feb 2012, 13:21 -
Attempting simple resize of MKV vids
By Jonodude in forum Video ConversionReplies: 1Last Post: 27th Nov 2011, 03:43 -
Resize MKV
By joe1974 in forum MacReplies: 1Last Post: 11th Jun 2010, 10:06 -
Requests...!! MKV & Progress Resize... !!
By moon47usaco in forum ffmpegX general discussionReplies: 0Last Post: 10th Apr 2008, 11:52
