I've been using vobsub (.idx/.sub) as external subtitles to my media files in my Blu Ray Player (BDP3200), but I guess vobsub format is intended to be used as a DVD subtitles, and, therefore, the images have lower resolution.
Is there anyway to bring higher resolutions to this format? Or .sup itself exists because of this limitation? I haven't tried loading an external .sup file, but the manual doesn't list .sup as playable subtitle format.
	Have you tried with text subtitles? srt is usually supported.
	If you have the PGS subs try loading in BDSup2Sub. Then export as idx/sub. http://milesaheadsoftware.org/
 Fully enabled freeware for Windows PCs.
	My Bluray Player's firmware works with small and thin subtitles for .srt, .ass and .ssa. The only on which it allows edition is vobsub. Anyway, the .srt or vobsub show up with poor AA, as Niksesaid.
 I guess I'll try to do as MilesAhead said, maybe converting .srt -> .sup, then .sup to vobsub.
 If I'm sucessful, I'll report back. =)
	You can go from .srt directly to idx/sub if the .srt file is ANSI. Use AviAddXSubs. I use it all the time to create idx/sub for my WD set top box. Like your player, .srt is shown very small and thin. idx/sub may not be great for anti-aliasing but with AviAddXSubs at least you can play around with font, font size, outline size etc..
 My WD only supports idx/sub as external file for white black and grey. So I have to compensate using font style and outline size.
 Myself I like Fontin font with outline size of 3.
 You can find a lot of free fonts here:
 http://www.urbanfonts.com/free-fonts.htm
 and on Softpedia.http://milesaheadsoftware.org/
	Thanks for the contribution.
 I've been using txt2vobsub, and I love the work it's doing, it's really fast and easy to use.
	I use that too. Along with txt2sup by the same publisher. Nice utilities. http://milesaheadsoftware.org/
  Old films to high definition?By therock003 in forum RestorationReplies: 39Last Post: 1st Jan 2015, 09:27
  High definition DVDBy rene-rottingham in forum Newbie / General discussionsReplies: 13Last Post: 21st May 2010, 07:35
  High definition conversionBy kypreo in forum Video ConversionReplies: 10Last Post: 21st Mar 2010, 23:15
  Help! How do I save my video in a high definition formatBy macleoda in forum Newbie / General discussionsReplies: 3Last Post: 3rd May 2009, 15:50
  video 8 to high definitionBy devdev in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th Jan 2008, 14:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
