Results 1 to 15 of 15
  1. I've got a DVD someone burned for me, which plays fine. But when I rip it, I get an L-EC uncorrectable error in DVD Decryptor. What's the issue likely to be?
    Home burned dvds do not have any protection. What happens if you just copy the files with windows explorer?
    You could also try free dvdfab decrypter and see how it works.
  3. Banned
    Freedonia
    This may be a sign of bad quality media with errors on the disc. Use the free version of DVDFab as it will continue to try to rip the disc forever until it finishes. Note that ripping it could take hours if the disc is bad. If you have at least 2 DVD drives on your PC you might try using a different drive for the rip.
  4. Originally Posted by Baldrick View Post
    Cannot read from the source.
    Error while reading.
    Bad disc would be my first guess, followed by bad drive, but it plays fine, which would seem to rule either of those out.
  5. Banned
    Freedonia
    Do you want help or not? Your conclusion is bs. Discs with errors may play fine on DVD players but be an absolute nightmare to rip. However, since it looks like you've made up your mind, I'm done here. Good luck.
  6. Originally Posted by jman98 View Post
    Which part of what I said indicated that I'd made up my mind? I said it would seem to rule out a bad disc or bad drive. Even if I'd omitted the word 'seem', there's still no indication that I've made up my mind, merely that I'm wrong. Which happens.
    On the other hand, you've also said DVDFab would continue to rip regardless of any errors, but it popped up an error message almost immediately when I tried to use it, so that can't be right either, unless I'm using it wrong.
    Dec 2005
    Pocatello, ID
    Looks like jman98 is having a bad day. Keep your chin up jman!
    Aug 2006
    What type of disc is this, DVD+R, DVD-R, DVD-RAM, DVD-RW, DVD+RW? By chance was it recorded by a DVD recorder, and not produced by a computer?
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    Try on another computer/dvd drive.
    Try isobuster or cdroller.
    Or maybe not finalized from a standalone dvd recorder?
  10. In DVDFab, you have to hit Retry a few times before it will start grinding away, if I recall. Been a couple months since I had a problematic disc.
    You can do the same thing in DVDDecrypter by setting retries to some high number, also setting it to ignore read errors.
    Good luck.
    Pull! Bang! Darn!
  11. CDRoller ripped everything except 1% of VTS_01_3.VOB. Imported into TMPGEnc, but it only imported up to approximately 20 seconds into VTS_01_4.VOB. Any ideas why that might be, and how to get the rest imported?
  12. 1. Try to convert VOB to MPG file. For example, use Split Video of CDRoller.
    2. Install appropriate codec. I successfully used free K-Lite Codec Pack ( http://www.free-codecs.com/download/K_Lite_Codec_Pack.htm ) when i faced to the same problem.
  13. Originally Posted by Nata View Post
    Did the trick. Thanks.
