Hi
I just bought a firewire card to transfer data from my Sony TRV110E (Digital 8 PAL Version) using Adobe premiere. I have got a XP 1700 with 512MB of RAM machine. I have quite a number of tapes which I need to convert so that I can free up the tapes for future shooting. I intend to convert those tapes to DVD later. However that will be a few months later as I am waiting for the price of DVD RW to go down further.
My questions is after transferring the tape to raw AVI format using Adobe, which format (MPEG1 or MPEG2) should I compress to for good quality when convert to DVD later? I will burned the final MPEG files to CD and store it till I got the DVD RW. What should be the setting on the Tmpegenc
My other questions is
1) Can I convert to SVCD and later to DVD? Will there be a quality lost?
2) Does 1 hour of camcorder captured equals to 1 hour SVCD and what about DVD?
3) Can MPEG1 be converted to MPEG2 or vice versa?
Apprecaite for the help.
Results 1 to 1 of 1
Rendering options
By MBS in forum Newbie / General discussionsReplies: 2Last Post: 24th Apr 2010, 12:17 -
Is there any player with these two options together ???
By moiz in forum Software PlayingReplies: 3Last Post: 2nd Nov 2008, 01:01 -
DIRECTV options?
By FatFreeVW in forum DVB / IPTVReplies: 0Last Post: 23rd Nov 2007, 15:48 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 22:31 -
what are my options
By bmw2007 in forum Video ConversionReplies: 2Last Post: 26th May 2007, 08:54
