    Aug 2002
    South Florida
    Using Imgburn, how does one turn off looping so that the disc does not replay in the Blu Ray Player. My Player has an "off" button but, it does not work. I would like to use Imgburn. TmpGenc DVD Author enables you to turn off looping.
    Oct 2005
    666th portal
    imgburn isn't an authoring program, you need to turn it off in whatever you authored it with, or use something like pgcedit to change it before sending it to imgburn.
  3. Using Imgburn, how does one turn off looping so that the disc does not replay in the Blu Ray Player. My Player has an "off" button but, it does not work. I would like to use Imgburn. TmpGenc DVD Author enables you to turn off looping.
    Looping (back to title set o1) is set while authoring DVD or BD. as said by aedipuss you can use pgcedit and overwrite loop instructions to exit so it will never be played over and over. Follow pgcedit guides and helps.
