Hey guys!
I am very new to After effect and Twixtor and have been reading up and watching a few tutorial. I am try to achieve a smooth slow motion effect during certain parts of some videos I took.
The set I am using is in the Composition setting I make the duration 30sec (the video to be slowed is only 7sec in total) I then select 'Enable frame blending with all layer', then Layer>Frame Blending>Pixel Motion. I then load the twixtor effect via the effects drop down. Open the twixtor output control menu. The issue I have is when finding the section I want to slow down I place a keyframe mark in the speed section, I then move a few frame and place another marker and change the speed to 20-30, then when I come to scan to the next part of the footage I notice that it has been shortend even though the full video was there originally.
Am I going wrong some where?
Because frames are added, the duration is longer. AE cannot extend the duration of the layer unless you precomp the footage first, or use nested compositions
See the instruction manual and this
http://www.revisionfx.com/support/faqs/generalfaqs/sequences_longer/ -
poisondeathray, you seem to be popping up and helping me a lot recently! Cheers!
Adobe After Effects issue
By Coroni in forum EditingReplies: 3Last Post: 22nd Oct 2010, 21:56 -
Twixtor for Adobe After Effects CS4
By Tahlos in forum EditingReplies: 4Last Post: 5th Oct 2010, 21:57 -
What is the best special effects/visual effects software?
By dzsoul in forum EditingReplies: 37Last Post: 10th Aug 2010, 00:16 -
After Effects: copy effects to another composition?
By squadjot in forum EditingReplies: 2Last Post: 8th Dec 2009, 20:16 -
Sound Card Compatibility with After Effects CS3 Issue...
By Angelus22 in forum EditingReplies: 1Last Post: 28th Oct 2007, 08:20
