    Jan 2001
    Does StaxRip have the option to keep the original AC-3 audio? I couldn't find the option if it does. I was going to either set the file size to 1.5GB or 2GB. What should I do about the resolution for a standard widescreen DVD?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    DVD "conversion" settings.
    Click on the audio codec(aac/mp3) under audio and choose Just mux.
    Jan 2001
    So by choosing "Just mux" that will keep the original AC-3 audio? Seems pretty simple
    Jan 2001
    What about the resolution? I know they are standard at 720x480... do I lower the resolution when setting the file size? Thanks
