i want to lock my media files being preview and play on any other pc and also link these files with a specific editing software.
can any body suggest me any software to do that easily??
thanks in advance
Moving you to our newbie section. This is not a guide.
No, you wont find any easy solution for this. Add instead a watermark. -
Instead of locking individual files , another approach is to use folder locking software that requires password (search google)
If you have your own site, you can just password-protect the whole folder containing your video clips from your site's control panel.
I'm thinking the OP, altaf, wants to create a video file that no one can use without viewing through a certain viewer/player app.
The only consistently reliable and yet still standards-compliant way to do this that I know of is to:
A. Create your own encrypted video codec standard
B. Make that codec's decoder dll work ONLY with a certain player app (with that app also custom-built by you)
C. Provide ONLY the decoder DLL and player app on your site - NEVER an encoder app.
What you will have done in the end is gotten to the same place that many security-video companies are right now.
But you must understand that THIS STILL DOES NOT GUARANTEE NO ONE CAN DECRYPT & RIP IT.
Ultimately, if you provide a means to display it (the decoder & player), you've provided an out for a decrypted version of the video, which can then be frame-captured/recorded to a separate standard codec, usable in standard players.
The axiom of "if I can see it, I can rip it" is still true.
So then you've gone through all that trouble to design & create a custom encoder, decoder, player, etc. only to get back to a state where you have to trust people to do the right thing...
Would have been alot easier to pick a different business model (or never show your video at all).
Fraps lock my framerate
By stranno in forum Capturing and VCRReplies: 0Last Post: 11th Jun 2011, 17:04 -
Code-lock Install Issues v2.5
By PhysicsMatt in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Jan 2008, 12:32 -
moduleC:\program files\badgerit\svcd2dvd v2.5\code-lock.ocx failed to regis
By itsjimmyb in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 30th Jul 2007, 08:41 -
why my jvc player is lock ?
By meeya in forum DVD & Blu-ray PlayersReplies: 2Last Post: 11th Jun 2007, 12:27
